Author Topic: repainting cab questions??  (Read 1737 times)
willybeamish
  • Last login:December 22, 2014, 01:59:10 pm
« on: September 21, 2012, 03:25:03 pm »
Purchasing a cab this weekend that could use a repainting and possibly some bondo to fill in any scratched up areas. Im pretty noobish so im looking for advice on what kind of paint would be best and what method of applying it to the wood?? I do plan on slapping on some graphics down the road but for now just wanna clean it up.
Currently rebuilding a PP cab and converting it to a mame cab..view the progress here http://forum.arcadecontrols.com/index.php/topic,122815.msg1305024.html#msg1305024
compute
  • Last login:February 26, 2018, 05:33:36 pm
Re: repainting cab questions??
« Reply #1 on: October 01, 2012, 07:34:06 am »
For my own cab, I did the following:
First I built a new bottom, since the water damage was so bad.  The particleboard had swelled to almost twice its normal size and would crumble if I looked at it funny.  Next time I'll hold out for a cab in better shape.  Live and learn.  If you have to contend with water damage, hopefully it's something you can seal/glue/bondo and sand to make it smooth and secure.
Then I bondo'd.  I had no experience with bondo, so it was a learning experience.  It sets in about 6 minutes after you mix it, so do small patches at a time.  I've heard of people using other wood filler compounds, but I've only used bondo.  Since bondo dries hard, do it before sanding.
To prep the surface for paint and smooth the bondo, I used an orbital sander with um..150 then 220 grit.  Something like that.  Auto finish nuts will insist on like 800 or 1000 or something like that, but I haven't found those in orbital disks and sanding by hand sucks.
For painting, I used a household oil-based latex paint.  Something like Bulls-eye.  One coat of primer, brush with 220 grit, then two coats of black sanding in between.  Again, I'm some nut with lungs full of paint will know better, but this worked for me.  I applied all three coats with a foam roller.  If you have access to and can use a hvlp spray gun, I hear the results are amazing.  Using a foam roller is pretty good, imo.
I followed some "rules" as I picked them up on the forum.  I've heard of people using water-based latex with no ill effect, or mixing bases for primer and color coats with no ill effect.  Ultimately, it's your cabinet, and your friends probably are not going to inspect the thing looking for where you filled holes (or didn't have the new 8" on the bottom QUITE even).  Especially after it gets artwork.
willybeamish
« Reply #2 on: October 04, 2012, 09:13:17 am »
So ill be attempting this next week..we did the same thing with the new bottom. I have to bondo the seams so you can see the difference in the wood. Also my cab was painted over the sticker or vinly and the paint literally flakes off. I planned on sanding it down past the old stickers to the particle board will most likely do latex paint...and then down the road do side art depending on how money it costs to have them made  :cheers:
willybeamish
« Reply #3 on: October 09, 2012, 01:26:47 pm »
Prepping the cab tomorrow for paint and bondo..Ive got access to a few different kinds of sanders and was wondering what do you guys recommend. Ive got to sand off the old vinyl sticker, the later paint that the original guy slapped on it, and scuff up the patch piece of wood.
