Author Topic: VGA to component trouble.  (Read 2990 times)
JOHN HOWARD
  • Last login:January 28, 2016, 10:10:17 pm
  • na na na na na na....
« on: September 19, 2012, 04:52:56 am »
I'm hoping you guys will be able to help, I'm trying to go from my PC (Nvidia GeForce 9800 GT) to a analog component TV via a VGA to component cable. after some tweaking in Nvidia control panel I get the image below. any ideas on how to get this to work properly?
TalkingOctopus
  • Last login:August 04, 2025, 03:48:02 am
    • My Arcade
Re: VGA to component trouble.
« Reply #1 on: September 19, 2012, 11:54:54 pm »
What TV is it?  The PC is probably outputting 480p instead of 480i.   Your TV might not support 480p.
JOHN HOWARD
« Reply #2 on: September 20, 2012, 08:43:38 am »
It's a panasonic Tx-29fx50a this is the manual (http://dl.owneriq.net/b/bafb2d49-c737-41a1-8c6e-d1eda3593bb8.pdf) o cpuldn't find anything about 480 compatibility, but how can i change that output from a pc to the TV??
TalkingOctopus
    • My Arcade
« Reply #3 on: September 21, 2012, 12:57:53 am »
What resolution are you outputting to the TV?  I think your video card expects you to connect the VGA to component cable to HDTVs.  You can get some videocards to output 480 and below using soft15khz.  Here's a list of compatible cards: http://community.arcadeinfo.de/showthread.php?7925-Getestete-Grafikkarten
JOHN HOWARD
« Reply #4 on: September 25, 2012, 12:17:19 am »
Thanks for your help, instead of buying a new card I bit the bullet and just decided to buy this from the local Jaycar store (Australia's equivalent of radio shack) http://www.jaycar.com.au/productView.asp?ID=XC4871
rCadeGaming
  • Just call me Rob!
« Reply #5 on: September 26, 2012, 09:59:52 pm »
That will look god-awful.  Start reading here:
http://forum.arcadecontrols.com/index.php/topic,121491.0.html
  • Online Online
  • Last login:Today at 11:14:57 am
« Reply #6 on: September 26, 2012, 10:12:16 pm »
i have one...
 and yes, this:
i also bought it for $12 off ebay. THIS ONE
« Last Edit: September 26, 2012, 10:17:50 pm by lilshawn »
Yenome
  • Last login:November 14, 2025, 04:36:28 am
  • Punch a fish. Make a wish
« Reply #7 on: October 01, 2012, 06:49:19 pm »
boot the pc in low res vga mode. f8 during post should bring up the list for it. i spam f8 when i need to get in to it. if it looks good then its cause your res is too high like others have said. my 32in tv does the same thing if its set above 480i.
