Author Topic: 720 standalone 8-way for DOS  (Read 955 times)
Wade
  • Last login:August 18, 2025, 08:14:20 am
  • 80's Child
    • Wade's Gameroom
« on: October 09, 2003, 04:45:09 pm »
While reading the most played ROMS thread I just realized I totally forgot about one of my favorite games: 720!  I REALLY wanted to play that on my cab but it just didn't play well at all.  I need the 8-way joystick hack but I use DOS mame.  Can someone do me a huge favor and build a DOS mame with the 8-way mod?  Standalone would be great, so I can just set it up as a different emulator in my frontend and not ever have to rebuild it when I update Mame.
Someone please hook me up.  BTW I went through the trouble of building mame once but the EXE ended up being HUGE compared to the release.  Why is that?
I guess if no one has already conveniently done this then I might go through the trouble one day at work when not much is going on.
Thanks,
Wade
papaschtroumpf
  • Last login:July 23, 2013, 11:41:10 pm
  • Have a Cow!
Re:720 standalone 8-way for DOS
« Reply #1 on: October 09, 2003, 04:57:29 pm »
The exe probably contained additional debug symbol information? Probably a compiler switch issue.
creatine28
  • Last login:July 26, 2012, 03:41:48 pm
  • Which way to the Arcade?
« Reply #2 on: October 09, 2003, 05:02:33 pm »
Thanks,
Wade
You need to use the the UPX program to compress your .exe down to a smaller size.
Here's the link.
http://upx.sourceforge.net/
jerryjanis
  • Last login:February 02, 2023, 01:56:44 am
  • Skate or Die!!!
    • Jake's Joystick
« Reply #3 on: October 10, 2003, 02:59:34 am »
I haven't tried it, but check out
http://www.urebelscum.speedhost.com/download.html
I looks like he's got Mame version .69 built for Dos with the 720 hacks.
(By the way, if you find that using an 8-way is unsatisfying, it's worth trying it with an analog joystick.  An analog joystick is able to process all 16-or-so directions, while the 8-way is limited to 8).
Also, check out my page with instructions on how to actually get it working:
http://www.jstookey.com/arcade/720/720-instructions.php
Wade
  • 80's Child
    • Wade's Gameroom
« Reply #4 on: October 10, 2003, 08:59:47 am »
Thanks guys, I forgot that he added it to analog+!  That solves my problem.
Wade
