Author Topic: For Dave_K about Mamed  (Read 3195 times)
Garvv
« on: May 03, 2002, 02:03:05 pm »
Hey Dave_K, I would've sent this to you via email, but your address is hidden.  Thanks for the info about mamed lockups, I am using DJ to burn the cd, and will have to try the newer version. You mentioned that you
played around with mamed a lot to get the perfect
settings, is there any chance you can send a .cdi file
my way with this optimized mamed?  No roms or
anything, just the optimized mamed.  I do have
NeoModus Direct Connect if you'd like to file share
it.
Also, I don't know if you've encountered anything like
this, but my new 10" svga monitor displays mamed and
nesterdc in a horizontal, split screen mode, whereas
my other two, larger svga monitors display them just
fine.  Given that mamed and nesterdc were gonna be two of the primary attractions of my bartop, this kinda
sucks... Any ideas as to a way around this?
Thanks,
Garvv
Garvv
Re: For Dave_K about Mamed
« Reply #1 on: May 13, 2002, 07:00:00 am »
Bump.
