Author Topic: 2 PacLed64's- Setting up?  (Read 2656 times)
iserian
  • Last login:March 08, 2017, 07:43:33 pm
« on: September 17, 2012, 01:44:53 am »
Each one on their own work fine, but when I try to hook both up via USB only one is seen by either Blinkey or the Pac64 utility.  What is the best way to go about setting up two to work together in one cab?
Setup -
Each PacLed 64 is connected to Power and USB (same computer).  I'd like to be able to control them as (ONE 42 Connection) - so that lights light across all 42.
Re: 2 PacLed64's- Setting up?
« Reply #1 on: September 17, 2012, 02:27:04 am »
Do they each have a different ID number?
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« Reply #2 on: September 17, 2012, 03:54:37 am »
The ID number is set using the config utility. It sounds like you have not set one of them to ID #2
Andy
iserian
« Reply #3 on: September 17, 2012, 09:41:28 am »
Thanks Guy's - I will check that out when I get back to the cab build this evening.  Glad to know that it's finally something simple :)
Trip
  • Last login:January 03, 2020, 01:37:04 pm
« Reply #4 on: September 17, 2012, 02:30:28 pm »
yep I did the same thing....  :lol
Definitely got to be set to two different ID numbers or windows doesn't like it.
