Author Topic: Tankstick Trackball not working in MAME 0.140  (Read 6901 times)
retrobill
  • Last login:September 13, 2012, 09:50:52 pm
« on: September 13, 2012, 11:46:02 am »
Hello all...I have mame ver 0.140 and for the life of me can't get the trackball on the tankstick to work.  The trackball works in windows and is fine everywhere but when I click on a mame game I can't get the trackball to work when entering in the mapping commands.
I do have mame plus installed and it work there so I am led to believe that it has to do with this ver of mame.  Is there a file that I need to address parameters or switches before the mame launches a game?  If so what is it supposed to look like?  Can I use another ver of mame or is mame all command line and the mame plus is more gui.
Thanks Bill.
pinballjim
Re: Tankstick Trackball not working in MAME 0.140
« Reply #1 on: September 13, 2012, 12:41:20 pm »
Edit mame.ini
Mouse 0 -> Mouse 1
retrobill
« Reply #2 on: September 13, 2012, 02:09:27 pm »
Thanks Jim...I think this is where my issue is...where is the mame.ini file supposed to be located?  and where is that mouse command to be located inside the file itself?
  • Last login:Today at 08:08:49 am
« Reply #3 on: September 13, 2012, 02:13:22 pm »
It's in the mame folder, right next to readme.txt
retrobill
« Reply #4 on: September 13, 2012, 05:25:03 pm »
I don't see it...this is what is extracted...do I have the correct mame downloaded file?
mickkn
  • Last login:February 25, 2021, 01:38:53 am
« Reply #5 on: September 13, 2012, 05:33:15 pm »
Guess there is a command for writing the ini file
Found this
http://forum.arcadecontrols.com/index.php?topic=38917.0
pinballjim
« Reply #6 on: September 13, 2012, 05:38:32 pm »
To summarize that linked thread...
Go to a command prompt, browse to your directory, type in:
mame -cc
That will create mame.ini
retrobill
« Reply #7 on: September 13, 2012, 05:40:17 pm »
I guess I will answer my own question...I have the binary version that requires you to FIRST create the mame.ini file by using the switch in a cmd prompt in the directory of mame and use mame -createconfig and then NOW does it all make sense!  This file is not created by default it just uses the default which in my case is no mouse...I had to create it and then I could now make changes.
Now I see said the blind man....
I think I am off and running now...I think.
retrobill
« Reply #8 on: September 13, 2012, 05:41:08 pm »
Thanks again Jim for your help...I was typing while you were answering my question...thanks again.
paigeoliver
  • Awesome face!
« Reply #9 on: September 13, 2012, 06:18:55 pm »
Nope, still doesn't make sense. Why in the world is it set to off by default in the first place?
retrobill
« Reply #10 on: September 13, 2012, 06:21:46 pm »
Taken from the config.txt file in mame
Controls whether or not MAME makes use of mouse controllers. When
   this is enabled, you will likely be unable to use your mouse for other
   purposes until you exit or pause the game. The default is OFF
   (-nomouse).
In the mame.ini file I changed the mouse to 1 and now everything works.
# CORE INPUT OPTIONS
coin_lockout              1
ctrlr
mouse                     1
joystick                  1
lightgun                  0
multikeyboard             0
multimouse                0
steadykey                 0
offscreen_reload          0
joystick_map              auto
joystick_deadzone         0.3
joystick_saturation       0.85
natural                   0
joystick_contradictory    0
coin_impulse              0
« Last Edit: September 13, 2012, 06:45:39 pm by retrobill »
willybeamish
  • Last login:December 22, 2014, 01:59:10 pm
« Reply #11 on: February 26, 2013, 09:28:48 am »
Bump from the dead..
Im in the same boat and was wondering if you had the trackball connected to the PC via PS2 or USB??
Currently rebuilding a PP cab and converting it to a mame cab..view the progress here http://forum.arcadecontrols.com/index.php/topic,122815.msg1305024.html#msg1305024
« Reply #12 on: February 26, 2013, 09:50:30 am »
Which are you using?
Does it work in windows?
willybeamish
« Reply #13 on: February 26, 2013, 10:08:00 am »
I have mine on USB and it works like a mouse fine in windows and will spin the Hyperspin wheel but I dont bother using it for that.
« Reply #14 on: February 26, 2013, 10:15:48 am »
Do you still have another mouse connected?  Does that one work?
You might have multimouse enabled, in which case input from each mouse is considered separate and only the first mouse is mapped in MAME.
multimouse              0
That will make MAME see all input as the same mouse.
willybeamish
« Reply #15 on: February 26, 2013, 10:40:23 am »
multimouse              0
I have a additional wireless mouse. Ill check the INI file when I get home for that. I originally never had created the INI file before and when I did at first it wouldn't work I believe because I had the mame stuff in a directory its not setup for. I moved it over C:Emulators/Mame and then typed C:Emulators/Mame/ Mame.exe -CC and I was able to find the Mame.ini right after.
willybeamish
« Reply #16 on: February 27, 2013, 11:32:30 am »
Got it to work finally, went into the Mame.ini set it to 'mouse 1' ..map the X and Y axis and your good to go.
