Author Topic: basic ac wiring help  (Read 2295 times)
ToiletPaperBandit
  • Newbie
  • Last login:October 08, 2003, 11:58:10 pm
« on: October 09, 2003, 12:28:27 am »
I’m wiring my cabinet according to the instructions by Bob Roberts available at http://www.dameon.net/BBBB/buildit.html.  An extremely helpful document for beginners, thanks Bob!!
My MAME cabinet will use a typical PC switching power supply and of course it has 3 AC terminals: neutral, hot, and ground . On the wiring diagram provided by Bob Roberts (see attachment in red) there is no ground wire running from the power distribution block to the switching power supply.
How should I handle the ground on the PC switching power supply??
Thanks for any help,
Jeff
Bob’s arcade restoration site is at: http://www.arcaderestoration.com
OSCAR
    • Oscar Controls
Re:basic ac wiring help
« Reply #1 on: October 09, 2003, 12:46:06 am »
The green earth ground wire pretty much ties all the components together in the cab so they are all at the same potential.  Although Bob's diagram doesn't show it, you could connect the ground wire to one of the mounting screws of the distro block, but it probably isn't necessary.
FWIW, I haven't had a cabinet yet that actually had a distro block.  It seems to have been more common to use jumper wires in molex connectors than using distro blocks in older cabs.
You can (should) run a wire right from the earth ground attached to your ac filter to the power supply.  I just replaced an old linear power supply with a switcher tonight in one of my cabs, and that is what I did.
