Author Topic: LEDBlinky, Ultrastik 360, Hyperspin and Sega Model 2 emulator  (Read 5193 times)
yakk11
  • Last login:April 23, 2025, 11:52:20 pm
« on: September 02, 2012, 09:22:09 am »
I have successfully configured the above combo for MAME.  Ms. Pacman plays perfectly now.   :)  However, when I try to use other emulators, like the Sega Model 2 emulator, it stays in 4 way mode.  I have tried adding the roms manually under the emulator section, but am not having any luck.  Here is my hyperspin log.txt
08:17:35 AM |  HyperSpin Started
08:17:35 AM |  Going FullScreen
08:17:35 AM |  LEDBlinky is set to active
08:17:35 AM |  Found LEDBlinky.exe
08:17:35 AM |  Running LEDBlinky
08:17:35 AM |  Command Line is: "C:\Program Files (x86)\HyperSpin\LEDBlinky\LEDBlinky.exe" 1
08:17:35 AM |  Checking for updates
08:17:35 AM |  Update Check Complete
08:17:35 AM |  Startup program: Xpadder.exe
08:17:35 AM |  Startup params not set
08:17:35 AM |  Working directory: C:\Program Files (x86)\HyperSpin\xpadder\
08:17:35 AM |  Window State: HIDDEN
08:17:35 AM |  Launching Xpadder.exe
08:17:35 AM |  Command Line is Xpadder.exe
08:17:35 AM |  Error intializing joysticks
08:17:35 AM |  Menu Mode is single
08:17:36 AM |  Loading MAME.xml
08:17:36 AM |  Command Line is: "C:\Program Files (x86)\HyperSpin\LEDBlinky\LEDBlinky.exe" 7 "MAME"
08:17:36 AM |  MAME.xml successfully loaded
08:17:36 AM |  MAME wheel loaded successfully
08:17:37 AM |  Command Line is: "C:\Program Files (x86)\HyperSpin\LEDBlinky\LEDBlinky.exe" 9 "sf2uk"
08:17:47 AM |  Command Line is: "C:\Program Files (x86)\HyperSpin\LEDBlinky\LEDBlinky.exe" 9 "sf2ceuc"
08:17:48 AM |  Command Line is: "C:\Program Files (x86)\HyperSpin\LEDBlinky\LEDBlinky.exe" 9 "sf2hfu"
08:17:51 AM |  MAME wheel loaded successfully
08:17:52 AM |  Command Line is: "C:\Program Files (x86)\HyperSpin\LEDBlinky\LEDBlinky.exe" 9 "vf2"
08:17:52 AM |  Launching Game
08:17:52 AM |  Command Line is: "C:\Program Files (x86)\HyperSpin\LEDBlinky\LEDBlinky.exe" 3 "vf2"
08:17:52 AM |  Using alternate exe Model 2
08:17:52 AM |  Running HyperLaunch.exe
08:17:53 AM |  Command Line is: HyperLaunch.exe "Model 2" "vf2"
08:18:36 AM |  Command Line is: "C:\Program Files (x86)\HyperSpin\LEDBlinky\LEDBlinky.exe" 4
08:18:37 AM |  Command Line is: "C:\Program Files (x86)\HyperSpin\LEDBlinky\LEDBlinky.exe" 9 "vf"
08:18:44 AM |  Command Line is: "C:\Program Files (x86)\HyperSpin\LEDBlinky\LEDBlinky.exe" 4
arzoo
  • Robots WILL kill you.
    • LEDBlinky
Re: LEDBlinky, Ultrastik 360, Hyperspin and Sega Model 2 emulator
« Reply #1 on: September 02, 2012, 03:43:11 pm »
Please turn on the Debug Log and Verbose options (on the Misc Options tab), run HS and the games/roms which are not working as expected, then email me the Debug.ZIP file - I'll take a look at your configuration.
Robots will kill you.
Arcade Addiction
yakk11
« Reply #2 on: November 22, 2012, 09:26:37 pm »
here is my debug.txt.  it looks like it is changing my u360 to 8 way, but i am not getting 8 way controls.  If i do a diag jump towards somebody using a keyboard, it works.  If i try it with the u360, it doesn't.  Is it because i am using xpadder?  I have that set up to map the arrow keys to my U360, i have it entered as an 8 way joystick in xpadder, but am unsure how to map diagonals ??
« Last Edit: November 22, 2012, 09:47:02 pm by yakk11 »
arzoo
    • LEDBlinky
« Reply #3 on: November 23, 2012, 10:49:41 am »
It looks like blinky is setting the maps correctly. I don't have any experience with xpadder - maybe someone else can help with that.
Arcade Addiction
yakk11
« Reply #4 on: November 24, 2012, 01:44:42 pm »
I disabled xpadder, reconfigured my emulators for my u360s and now 8 way works for everything.  But now i cannot control hyperpin.  Does anybody know of ANY workaround for this that works for all emulators and not just for MAME?  I am using Windows XP Pro 64bit with groovymame.  I know that changing to the 32 bit version of the OS seems to fix this problem, but I do not want to switch.
