Author Topic: Neo Geo marquees with the full red "one-slot" layout??  (Read 2373 times)
arcadecab
  • Last login:September 26, 2007, 06:17:06 pm
« on: October 08, 2003, 09:36:50 pm »
Does anyone know where to find the Neo Geo MVS marquees that hold the one-slot mini-marquees.   I am using them in MAMEwah with the artwork stretched to fit and obviously the mini-marquees get distorted incredibly.  I would really like the look of the red one-slot marquee with the Neo Geo mini-marquee inside it.  Anyone have these or know where to get them.
Thanks.
« Last Edit: October 08, 2003, 09:37:45 pm by arcadecab »
BobA
  • What Me Worry?
Re:Neo Geo marquees with the full red "one-slot" layout??
« Reply #1 on: October 08, 2003, 09:53:49 pm »
Here is one but hopefully someone has one that is higher res.
BobA
arcadecab
« Reply #2 on: October 09, 2003, 01:38:02 pm »
BobA,
Thanks.  That would work just fine, but any ideas how I would get the mini-marquees to appear in the window of the marquee so that when used with MAMEwah, it would all be one unit?
TalkingOctopus
    • My Arcade
« Reply #3 on: October 10, 2003, 12:09:05 am »
Here is an idea that may work.
Save the red marquee as a gif with the mini marquee square transparent.  You will have to have a copy of that for every neogeo game.  Then set up another artwork in mamewah for the minimarquee.  Put that under the transparent part of the neogeo marquee.  When there is not a neo geo marquee, then it would not be visible.
It would require some work but may be possible.
