Author Topic: Space simpsons - new cp - art advices needed  (Read 14494 times)
Nestafari
  • Last login:August 21, 2019, 09:08:58 am
« on: August 31, 2012, 01:16:44 pm »
Hi, i wanna buy a gutted cab for a mame project and i ve found this :
It s only 21'' of large and 5 feets high.
Price 150$ -> a bit expensive. There are speakers and screen but not in a perfect state. T molding is new.
Do you think it is high enough to play in a stand up position? I wanna make a 2 player panel with 6 buttons each is it big enough?
What do you think ! And the screen is not vertical enough..I think the biggest i can put in it is a 19''...Bit tiny??
Anyway i really like the style and the size but is it gonna be a problem while playing with a friend?? I am tall btw..
ah yeah i also wanna put this cab on wheels so can win a few inches high...
Sorry for my english and thanx for your help !!  :angel:
« Last Edit: August 06, 2014, 07:07:43 pm by Nestafari »
Space Simpsons cab in progress
bluemini17
  • Last login:June 06, 2014, 10:26:11 am
    • My Youtube Channel
Re: Gutted POKER cab???
« Reply #1 on: September 03, 2012, 07:26:24 pm »
It looks like a good base to do your own thing. I have a cab of similar size and design. I went for a two player setup but only 4 buttons per player. I have an original hantarex 20inch screen in it. works a treat. i like the size and angle of the screen
Nestafari
« Reply #2 on: September 04, 2012, 10:03:10 am »
Do you have any pics of your finished cab??
Is there enough room for 6 buttons? How does it feel during a two player game? Not too cramped?
Thanks for your help.  :)
Yvan256
    • Yvan256
« Reply #3 on: September 04, 2012, 02:22:23 pm »
This cabinet looks like a good compromise between a lowboy and a regular stand-up cabinet! Anyone recognize the shape? Is it an original cabinet that has been modified into a poker cabinet?
I'm not sure if it's worth 150$USD but there is already a coin door and the cabinet seems to be in great shape. If the speakers are good and there is two of them (i.e., stereo sound) then it's also one less thing to worry about.
Since you say the monitor is burned-in, you might want to offer a bit less for the whole thing for the trouble of removing the monitor and disposing of it.
Nestafari
Re: I've got a gutted cab ! (advices needed)
« Reply #4 on: September 04, 2012, 03:03:46 pm »
Ok so i ve bought this cab with speakers, t molding, and in a good state.
Well, actually, i want it in a perfect state.
So i m gonna put a new layer of paint -> question do i have to sand down first?
The marquee looks a bit smaller and is unusual, i hope i can change it easily
-> question can i fill the holes with something instead of rebuild the board of the coin door?
More pictures to come..Thank you everyone
Ps i think i will make a gouls and ghost cab but not too dark  :burgerking: , artwork coming soon !
bluemini17
« Reply #5 on: September 04, 2012, 03:10:39 pm »
Thats great on the purchase. I measured mine today, it is 23inch wide. I am happy with two players but you have to stand slightly over to the side when playing. 6buttons would be tight but possible. here is a video of mine so you can get a feel for the control panel size.
MacGyver
  • Last login:December 18, 2023, 12:49:00 am
    • Project Build
« Reply #6 on: September 04, 2012, 03:22:53 pm »
Are you sure that it's paint?  It looks like black Melamine or vinyl.
Nestafari
« Reply #7 on: September 04, 2012, 03:29:17 pm »
 :notworthy:
-> How did you fix the screen?
-> How do you open the CP?
-> where did you print the artwork?
Great job, thanx for the vid !!
« Last Edit: September 04, 2012, 03:39:10 pm by Nestafari »
bluemini17
« Reply #8 on: September 04, 2012, 03:43:47 pm »
I fixed the screen by replacing the capacitors. It is mounted using the original mount. It connects to the PC using software called SOFT15KHZ and a pci video card.
the control panel is held in place with 'clamps'. They are used on most arcade machines. you stick your hand through the coin door and reach up and undo them.
google this 'arcade control panel clamps'
try this link, its the silver thing http://2.bp.blogspot.com/_p21BV9S5a0k/TNx_iDiLvBI/AAAAAAAACV8/WIi_Cqrwth0/s1600/ControlPanelBase.jpg
the artwork is a lion-o poster stuck on with glue
Nestafari
« Reply #9 on: September 04, 2012, 03:49:56 pm »
Noob questions but thanx for the answers...You reach the clamps through the coin door...hu hu..  :angel:
Well Fed Games
  • Last login:October 08, 2025, 04:49:48 pm
  • Delicious!
« Reply #10 on: September 04, 2012, 06:06:35 pm »
For those holes on the front, I would find dowel rods of the proper diameter or use a hole saw and make some plugs, glue them in, and then bondo and sand to make everything match... you would never know they were there. If need be you can put a brace on the inside of the hole to help give it a temporary backing.
Nestafari
« Reply #11 on: September 04, 2012, 08:20:22 pm »
Nestafari
« Reply #12 on: September 04, 2012, 08:21:40 pm »
You are right It looks like black Melamine or vinyl.
How do i remove this sh**?
  • Online Online
  • Last login:Today at 11:48:48 am
« Reply #13 on: September 04, 2012, 08:24:32 pm »
If it's vinyl a heat gun and scraper should do the trick IIRC.
Nestafari
Re: Gouls and ghost cab Naked + pictures and questions
« Reply #14 on: September 06, 2012, 09:45:34 pm »
Hello,
I wanted to remove the vinyl and as it is very difficult without a heat gun and that i want a full artwork...I said to myself, why dont you just fill the littles scratches with sand and stick your artwork on it?
- Is it a bad idea and if it is, why?  ???
Secundo, i remove the old screen and think i m gonna put a flat one, i ve found some "square" screens very cheap ! Is it working ok or do i need smthing else?
Go back to the absolute...
I remove marquee..It is very skinny but i hope that i will be able to make a good job.
The bad point is..I want to put some wheels and the cab is not tall enough in my sense so i wanted to make it higher...But it is already done on over more than 10 centimeters (picture one..)..
So what do i do with that?? I just plug the wheels and that s it or i make it higher and it ll be awfull?
What is the best way to paint the coin door as new? Do i sand it first? What kind of aerosol is needed to have the hammer effect??
The clamps for the CP are on the side but i want to haver flipper buttons do you think it is possible?
Thanks for your advices  ;)
« Last Edit: September 06, 2012, 09:51:36 pm by Nestafari »
  • Online Online
« Reply #15 on: September 06, 2012, 11:57:36 pm »
I don't have all the answers for you, but here are a few to get you started:
The main drawback is the fact that the cab looks like it has been on location for quite a while.  Seems like the vinyl texture would trap a lot of the dust, dirt, grime, cigarrette smoke, spilled drinks, etc.
If you don't prepare the surface properly for sideart, it will curl up or peel too easily.  See Rikitiki's Side Art Install 101 thread and associated videos.
The adhesive on printed sideart is less sticky than some other applications to allow you to smooth it out and avoid bubbles and wrinkles.
The vinyl is thin enough that it will show the texture underneath it.
If you're going to spend the money on printing nice sideart, you can spend the time, money and effort doing a proper prep job or you can  :angry:  when it comes out looking . . . not so good.
Think of it like doing a back handspring on cement:
- Doing nothing is OK.
- Doing it all-the-way is OK.
- Doing it half-way is no good.
The thickness of the cab side (3/4"?) plus the panel support (3/4"?) makes it too thick (1-1/2"?) to mount the microswitch on regular buttons.
You could use Ultimarc's Goldleaf buttons since they don't have the microswitch/wires coming off the side.
Use a 1 1/8" hole through the outside of the cab and a little bit larger one through the CP support piece so you can tighten the button nut with a button wrench like this one.
mgb
  • North East, US
« Reply #16 on: September 07, 2012, 07:04:41 am »
Don't rely on artwork covering up partially pulled vinyl and scratches. Its a pain at first to strip vinyl with a heat gun but once you get going, its not so bad.
Nestafari
« Reply #17 on: September 07, 2012, 09:11:35 am »
Thanks for the advice for the flipper buttons !! This will be perfect !
For the vinyl on the side..I m gonna find a heat gun ! That's it that's all  :angel:
Thank you !
mgb
  • North East, US
« Reply #18 on: September 07, 2012, 01:55:18 pm »
Yes, definitely use a heat gun. Its real tough without one.
Not sure what part of the world your in but Harbor Freight stores will have them real cheap.
In a pinch once, I used an iron with some material between the iron and the vinyl so it wouldn't melt on the surface.
Nestafari
« Reply #19 on: September 07, 2012, 02:50:01 pm »
Bad news...It does not work with the heat gun !!
The wood burns the vinyl stays and so on..
So i get my money back to the shop and ask a "Pro" he told me that the best way was to sand it...Even a cleaner, remover does not work (apparently)...
So i ll sand it  i guess ^_^
Nestafari
« Reply #20 on: September 07, 2012, 02:54:11 pm »
Not sure what part of the world your in but ...
What the??
Dont you see the Canadian Beaver Mario on my side?
Anyway i m from Belgium but live in Canada (Montreal)..Now you know everything !
Well Fed Games
  • Delicious!
« Reply #21 on: September 07, 2012, 08:49:39 pm »
I've had good luck removing vinyl of all types with a citri-strip type paint stripper, tried a couple different brands (it is thick, almost a gel), and it works well. You just end up with a bunch of rubbery vinyl sludge all over the ground afterward (put newspaper or something down). Was the only thing I could take the vinyl off an old Kangaroo cab with.
http://www.homedepot.com/buy/citristrip-1-2-gallon-safer-paint-and-varnish-stripping-gel-hcg73803t.html#.UEqVytZlQ3I
Nestafari
« Reply #22 on: September 29, 2012, 06:34:43 pm »
Hi everybody,
I ve got some news. Nothing amazing but i keep going.
I sand this *** vinyle..Hard job but now it s ready to receive a nice artwork.
I ve cut the CP, i m ready to order the pushbuttons.
I ve put wheels, it is a bit higher now and easy to move  :)
I ve bought a 20' flat screen LCD 4/3 and i find the result very nice.
I know how to fix it in the cab..
My questions :
- Where can i order the artwork? I live in Montreal and i want it cheap of course..
- What do you think about this for the cp? -> I m afraid that the pushbuttons will destroy the drawing..Maybe i will do smthing around the pushbuttons and joystick, it is more...Professionnal !
- The second one for the marquee..I will add a back ground i think
Pictures of the cab soon !
Thank you
« Last Edit: September 29, 2012, 06:38:49 pm by Nestafari »
Jigenjuke
Re: Gouls and ghost cab "ArtworK?"
« Reply #23 on: September 29, 2012, 09:16:12 pm »
Hi everybody,
My questions :
Thank you
Hey there Nestafari,
I think that it would be pretty cool if you could get some original art action for G N' G.  I always thought that the art for this Capcom cabinet was pretty bland.  But if you want something like the original you should go here.
Game on Graphix
http://www.gameongrafix.com/categories/all-products/page-51/
They have the Marquee, Bezel and Sideart.  I will send you picture of the CPO but it is a little small you could try resizing it in Illustrator and see what happenes.
Or you could contact Lord Hyrule, he made some really awesome artwork for this cab.  He is a spanish speaker and I am not sure how much English he speaks but if you could get his art your cabinet would really POP!!
Jigenjuke
Nestafari
« Reply #24 on: October 07, 2012, 12:51:37 am »
Well, i dont like the original artwork of the gng cab but this game is just awesome !! :dizzy:
I want something more personal, that s why i ve asked you what you was thinking about those two pictures for the cp and marquee..For the side art i will i will put my hero with some great colorz in the back..
More very soon thx
Nestafari
Re: Space simsons "ArtworK?"
« Reply #25 on: October 12, 2012, 06:41:02 pm »
I ve change my mind for something "better" i guess..
I m gonna make a Space simpsons cab...
What do you think?
Thx
johnm
  • Last login:September 27, 2025, 01:42:49 pm
Re: Space simpsons "ArtworK?"
« Reply #26 on: October 13, 2012, 10:16:03 am »
No Kang?
Nestafari
« Reply #27 on: October 13, 2012, 11:02:29 am »
Not a bad idea..
I ve a question how can i check if the draw fits my cab?
Do i have to take a picture of my cab?? Is there any solution?
Thx
Nestafari
« Reply #28 on: November 18, 2012, 02:56:54 pm »
ARTWORK READY FOR PRINTING !
Any comments?
THX
Side, Kickplate and Marquee !
Nestafari
« Reply #29 on: November 18, 2012, 04:40:06 pm »
I ve forgot...
THE CP
« Last Edit: November 18, 2012, 04:41:38 pm by Nestafari »
« Reply #30 on: November 18, 2012, 05:03:51 pm »
Hahaha!  That's pretty cool.  Nice stuff!   :cheers:
  • Online Online
« Reply #31 on: November 18, 2012, 05:43:10 pm »
You might want to add crosshairs for joystick centering.
Not quite sure about those light-blue button halos, though.   :dunno
Nestafari
« Reply #32 on: November 18, 2012, 06:00:50 pm »
Any idea?  ???
  • Online Online
« Reply #33 on: November 18, 2012, 06:13:40 pm »
Any idea?  ???
What color player and admin buttons are you using?
Nestafari
« Reply #34 on: November 18, 2012, 07:18:32 pm »
Hi Scott,
admin button Leftside 1yellow 1white
                      Rightside 1yellow 1white
Player 1 Green
Player 2 Purple
An old idea was this...
Thank you for your advices !  :angel:
  • Online Online
« Reply #35 on: November 18, 2012, 07:59:51 pm »
I like the glowing gas clouds better than the solid light-blue halos.  Fits better with the space theme.
Would the player button halos look better at their current size or closer to the size of the admin halos?
Also consider adding crosshairs in the white center of the donuts like you have in the buttons if you plan to use the art to mark your CP for drilling.
+1 if you undermount your joystick dustwashers or find clear dust washers if on top.  Either way be sure to black out the inside of the panel joystick holes.
wol-nz
« Reply #36 on: November 18, 2012, 10:39:38 pm »
i think all the components are great - but the cohesion is lacking.
Try to imagine how the art will look once on the cab - i think the kick panel with the bright blue star burst will take center stage.
The marquee and side art go together quite nicely.
If it was me i'd either put the starburst background on the control panel and lose the button halos altogether.
or
give the kick plate the boot altogether.
In saying that - if you like it then that's all that matters  ;D
KeithPuetz
  • Last login:May 27, 2017, 04:26:21 pm
« Reply #37 on: November 20, 2012, 10:51:30 am »
This cabinet pretty much REQUIRES the aliens on the cabinet. It's sort of disappointing you are not putting them in there. I think you should redo the sides, and do it pretty much the same concept with the ALIENS instead of the family. And do the kickplate all stary (like the cp) with the current side image (the family) where the kick plate is.  :afro:
« Last Edit: November 20, 2012, 10:53:04 am by KeithPuetz »
steveh
  • Last login:January 29, 2024, 09:33:42 am
    • thecrazysteve.com
« Reply #38 on: November 20, 2012, 12:11:43 pm »
Your killing me not having kang and kodos on there  otherwise i like the theme.  i like the donuts for the cp. thats really clever.  i have to agree about the stars, each piece of art looks great, but together they dont seem to flow properly the stars should appear on each one, maybe at the top of the markee, and side art.  and fade away as for the kick plate  it does not look like it belongs at all.
im a huge simpsons fan, and i love the idea.  im still really torn on what to do with my cab.  im going to follow this close cant wait to see how it all turns out.
Nestafari
« Reply #39 on: November 21, 2012, 10:32:47 pm »
Thank you for all your advices...
Actually it was very hard to decide what to do...
I love the simpsons family but the theme space simpsons is in relationship with space invaders
That s why i dont want to present Kang on the cab...I just present the simpsons family and no one else
That s right but with the black coin door i hope it wont be too flqshy disco..
I m not a huge fan of the cp with the stars..
I m afraid that the colors of the buttons with the blue halos is gonna look weird but, he, i take the risk.And i like the way it looks clean and #sur mesure#
So i know it s not perfect but i hope it is gonna look good..
PPrinted with Souldraw for 70dollars..I hope the result will be nice.
Thank you for the support
