Author Topic: Radeon 4350 driver problem  (Read 7224 times)
djcasey
  • Last login:August 24, 2025, 06:07:43 pm
« on: August 31, 2012, 05:04:24 am »
hi
I bought and instaled new card Radeon 4350 512MB
this model http://www.msi.com/product/vga/R4350-D512H.html
its working quit nice, but i doesnt recognize vga input
http://imgur.com/i71Ve,EYHVT#0
PCI\VEN_1002&DEV_954F&SUBSYS_16121462&REV_00\4&196AFE53&0&0008
PCI\VEN_1002&DEV_954F&CC_030000
a vga port is Unknown PCI device
http://imgur.com/i71Ve,EYHVT#1
PCI\VEN_1002&DEV_AA38&SUBSYS_AA381462&REV_00\4&196AFE53&0&0108
PCI\VEN_1002&DEV_AA38&CC_040300
the result is each time i started WinXP, it ask for driver for PCI device
i'm using crt_emudriver_9.3 xp 32bit
Mayby someone can help me what to do ?? maybe drivers need tu be updated ??
Calamity maybe You can help ?
« Last Edit: August 31, 2012, 08:41:21 am by djcasey »
Sledge
  • Last login:August 02, 2025, 01:37:53 am
Re: Radeon 4350 driver problem
« Reply #1 on: August 31, 2012, 06:27:53 am »
have you checked either of these threads? might be the same issue.. though i have a gigabyte HD4350 and it installs fine.. only issue with mine is the screen isn't registered as a PC monitor so the video card somehow stops the PC from booting.. had to use a different card..
http://forum.arcadecontrols.com/index.php/topic,120690.0.html
http://forum.arcadecontrols.com/index.php/topic,122039.0.html
djcasey
« Reply #2 on: August 31, 2012, 06:36:26 am »
i checked this threads, i also tied the files - no results
drivers recognizes my card, but only DVI works, it doesnt install drivers for vga port, and system asks for it each time i start win xp
i dont need vga port working, but driver missing pupup is quiet anoying
« Last Edit: August 31, 2012, 06:54:12 am by djcasey »
Sledge
« Reply #3 on: August 31, 2012, 07:20:16 am »
in device manager, right click on the device causing the popup and click - disable
that should stop it maybe?
  • Last login:February 19, 2026, 06:15:36 am
« Reply #4 on: August 31, 2012, 07:45:12 am »
Hi djcasey,
What those posts show are the files that need to be modified in the driver install files (before installing). You need to edit those with *your* PCI values. I've done this for other people but don't have time to do it at the moment, sorry. It's quite easy to do anyway. The problem is that the drivers don't recognize your somewhat unusual PCI value of AA38.
djcasey
« Reply #5 on: August 31, 2012, 07:55:44 am »
tried that dont work ...
djcasey
« Reply #6 on: August 31, 2012, 07:57:29 am »
Hi djcasey,
thx for that information, but what files need to be modified ?? maybe i'll be able to do it, let You know, if not, pls made the changes and post them with your free time
edit:
do i need only to modiffy file CX_76825.inf
and add line:
"ATI Radeon HD 4350" = ati2mtag_R7X, PCI\VEN_1002&DEV_AA38
or smg else ??
im really noobie on this ;p
« Last Edit: August 31, 2012, 08:56:12 am by djcasey »
« Reply #7 on: August 31, 2012, 09:29:39 am »
Look at the attachment here:
http://forum.arcadecontrols.com/index.php/topic,120690.msg1280715.html#msg1280715
Yes, you need to add that line there. Also add the AA38 device to the other files too.
« Last Edit: August 31, 2012, 09:32:21 am by Calamity »
djcasey
« Reply #8 on: August 31, 2012, 09:33:40 am »
i saw this file before, but nothing else pop up im my head besides this line
if smg else let me know, but i'm affraid its over my strengh, but i try...
when you find some free time pls upload this file
