Author Topic: My two player bartop finally complete!  (Read 9479 times)
agent_c
  • Last login:September 19, 2023, 02:14:47 am
« on: August 23, 2012, 06:17:59 am »
     Just thought I'd post some pics of my now complete bartop, no plans were made just me and almost endless revisions and amendments in the garage, only regret was the name! (Name is ok but makes me have to use hyperspin.) But once sent the artwork to the printers no going back without spending more dough!
     The system is based on a sandybridge G840 on a MSI H61M-P31-G3 motherboard with 4gigs of ram, graphics are handled by a low profile Sapphire  HD 6570 1GB DDR3 as i found the inbuilt graphics not up to the job.
     Reason for building it was, I have an original Virtua Racing upright machine and got tired of my two sons friends playing on it and abusing it's beautifulness!
     My first build after many years of thinking about it!
« Last Edit: August 23, 2012, 06:42:33 am by agent_c »
agent_c
Re: My two player bartop finally complete!
« Reply #1 on: August 23, 2012, 06:19:40 am »
     Side art does have a minor button alignment issue with commando but no worries! I had an illustrator trial time limit so was kinda rushed on art, it shows a little but so far no one has complained!
« Last Edit: August 23, 2012, 06:45:10 am by agent_c »
agent_c
« Reply #2 on: August 23, 2012, 06:22:07 am »
Closer look at the cp, just simple functional layout.
agent_c
« Reply #3 on: August 23, 2012, 06:25:00 am »
Bending the 3mm perspex over the cp was the hardest part! Then having done it correctly I had to drill holes in it....
jmike
« Reply #4 on: August 23, 2012, 07:01:38 am »
 :applaud: :applaud:
           Wow! Very cool. Did you do the artwork yourself? (any chance you're sharing it  ;)
What size monitor is that, it looks pretty big. Would love to see more pics, especially of the inside.
Great job
agent_c
« Reply #5 on: August 23, 2012, 08:39:35 am »
:applaud: :applaud:
Great job
thanks for that, other than a background image(which fitted my design and was on a free vectors site),  all the artwork was various character vectors resized, flipped etc from the arcade artwork section (I have a link somewhere) Then i added a blue/dark blue sunburst i made from a youtube tutorial overlaid on the background the added all my characters and bingo, I wanted an explosion under (layer) donkey kong so it looked as if all the art was flowing out from that but time killed that idea!
      The monitor is 19. 4.3 dell i picked up locally for £20.
      I will post some internal pics later, I removed the psu from it's case so it saved space and also the monitor was de-cased for the same reason, the hdd is a standard 500gig sata 3.5" mounted on the back of the monitor support.
     The cpo artwork i posted a few weeks ago on Nipson's "feels like I'm missing something" artwork post but have added some 3d elements to it and a colour change of backgound to buttons which improved it no end.
I am happy to post the artwork but never know what format to post in as some people like photoshop and some illustrator, I only used illustrator so have saves in ai, pdf, eps and jpg. If you want them let me know and I'll post in the "free artwork" thread in whatever format suits you. As a side note the numbers and words are all converted to line art so are embedded as they are seen and not as fonts      (worked that out after going to printers with disko font non embedded!)
« Last Edit: August 23, 2012, 08:45:42 am by agent_c »
agent_c
« Reply #6 on: August 23, 2012, 08:52:44 am »
Forgot to add one little thing! I made a 4way/8way electronic motorized switch system to change the player 1 joystick by a single button press which will go on the back, I have not fitted it yet as I think it may be overkill!?
   The joysticks are sanwa and have a large round movable gear on them to mechanically change to 4way/8way I couldn't resist making an electronic switch to move the gear using the pc 5v output!
    I'm an electronic engineer by trade and ........well see problems to resolve everywhere!!!...!!!
« Last Edit: August 23, 2012, 10:21:39 am by agent_c »
jmike
« Reply #7 on: August 23, 2012, 09:20:27 am »
 :applaud: :applaud: :applaud:
        Nicely done. But what about the trackball  ;D?
PDF or jpeg for the art would be good.
  • Last login:Today at 10:30:50 am
« Reply #8 on: August 23, 2012, 09:38:25 am »
Sweet - very nice job.  Ultimarc now sells a motorized 4/8 way switchable joystick.  Maybe look into getting one of those?  I think you can have it switch using software depending on the game selected.   :cheers:
agent_c
« Reply #9 on: August 23, 2012, 10:20:18 am »
jmike
I'll put the artwork in the freebie art thread tonite, as for the trackball I bought this one http://www.ebay.co.uk/itm/280913244016?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649 but found it totally impractical for my purpose! So i used an old g5 lazer mouse i had and using the ball mount (with rollers) and the ball made my own trackball, little bit of soldering and track cutting made it invert the x axis, added the greem led's and there you go!
Pdf is better as you can create reliable vectors from it and inkscape supports it better as pdf.
 I just saw that after your post! Oh well i made my own, no software control just a micro switch for the end stops pretty simple on/off desgn! As I said not put it in (yet) not sure if it's needed.
« Last Edit: August 23, 2012, 10:23:08 am by agent_c »
agent_c
« Reply #10 on: August 23, 2012, 01:08:23 pm »
As requested here are some pics of the insides, the cp has a layer of steel then freefoam on top which the vinyl was attached and the 3mm drilled & thermoformed perspex on top of it all.
I will have to ask to  post the artwork on the "freebie art" thread as it is someone elses work and I don't want to tread on anyones toes.
« Last Edit: August 23, 2012, 01:13:04 pm by agent_c »
agent_c
« Reply #11 on: August 23, 2012, 01:10:20 pm »
little closer shot inside.
agent_c
« Reply #12 on: August 23, 2012, 01:11:18 pm »
underneath the cp, warts n' all!
mgb
  • North East, US
« Reply #13 on: August 23, 2012, 11:33:52 pm »
Very nice bartop. Great job.
Woodshop Flunky
« Reply #14 on: August 24, 2012, 02:23:05 am »
Very nice looking build.   :applaud:
swaffar
« Reply #15 on: August 24, 2012, 06:58:41 am »
Looks good!  Too bad you can't play Golden Tee with that trackball so close to the screen.
My projects:
agent_c
« Reply #16 on: August 24, 2012, 08:58:54 am »
Thanks swaffar
 I knew that from research into adding the trackball but space is a premium on the cp I wanted it for the popcap games and also missile command, snacks 'n  jackson.
Would have loved a spinner but there's only so much you can fit in so compromises had to be made! The total size of the cp layout is 450mm x 250 mm and you have to have space behind the joystick for your hands to rest! Below is a picture of the machine before i added the trackball.
There is a tinted perspex protecting the screen but I have to agree with you on placement.
 My next build may be a mini version of your "digipin" as i have spare 15"(4:3) 7"(16:9) and a 19"(16:9) monitor but is the 19 too small for the table/bed? What do you think?
« Last Edit: August 24, 2012, 10:05:56 am by agent_c »
agent_c
« Reply #17 on: August 24, 2012, 10:03:45 am »
this is what it looked like before i felt it needed the trackball.
mytymaus007
« Reply #18 on: August 26, 2012, 01:39:39 pm »
Nice cab. How did you bend the perspex without taking the paper off it or did you not have that in the original. Also how wide is the cab. As for the trackball how did you line up the whole without any mounting brackets. Awsome work!!
agent_c
« Reply #19 on: August 27, 2012, 04:28:36 pm »
Thanks for asking, the freefoam (middle layer of my cp with the green freefoam cover plastic in the above picture) comes pre bent it is designed for under the eaves in houses (called soffits/facsias here in uk) I have a lot of spare after a recent extension and tbh it's excellent for a cp even without perspex because it's gloss white and smooth, the perspex was bent with the heat gun method. I have to admit there were 7 or 8 attempts with 2mm glodex (brandname) perspex which never satisfied me, Good job the stuff was only £6 a sheet and i got 4 attempts off each sheet. I found after bending a day or so, 2mm crazes internally which is due to cooling too quickly!
I mastered it toward the end of the 2nd sheet but as i needed the tinted sheet for the monitor I found it was cheap enough to order a clear 3mm piece with the tinted one as postage was the same for two, boy am i glad I did cos taking my time and clamping round the freefoam underlayer I was careful and slow to bend exactly as needed with the protective sheet still on, i made sure to keep the sheet warm for about an hour or so after still in clamps gradually lowering temperature by the distance method.
   Drilling it was the worse part cos having got the bend right, then waiting 2 days to check for crazing in the bends, the drilling had to be spot on too.
All the components (trackball sticks) are mounted on a 2mm steel plate then the freefoam is laid on top with crude recessed cuts to hide the screwheads without the freefoam being uneven (freefoam is 10mm thick and easy to work), the freefoam and 3mm perspex is held on to the steel by the actual arcade buttons and nothing else, so the top surface is smooth as there are no screwheads on show. the whole machine is 600mm high by 450mm deep by 450mm wide.
  The trackball mount is crude at best but it is functional if you look in the underside picture you'll see that the mount is just a rough cut 3mm plastic sheet (actually part of the de-cased dell monitor!) which was drilled with corner grooves rather than holes (just like the corner of the joystick mounts thesedays) so i could adjust to fit the hole rather than cut the hole to fit the trackball, I designed in 3mm all round to play with after aligning all 3 layers of the cp.
   One more thing to add, I have now played golden tee golf on the machine and can regularly make drives over 300 yards without hitting the screen cover! The distance between end of trackball and screen is 30mm or 1 &1/4 inch. the trackball is very easy to move, hardly any friction at all. I think because I over polished the rollers and guides before I put the trackball in.
   The picture below shows the old layout before the added artwork and trackball, just freefoam on top of the steel, (no green coverplastic) and  NO perspex and you can see freefoam looks quite good without artwork or perspex. The white plastic frame for the internal part of the monitor bezel came from flooring door trim so hides the routed internal edge of the bezel wood. As with most of the "trim" they were things I had lying around which is why I started the build in the first place.
   The eagle eyed of you will also notice the plastic strip under the  monitor is different in the completed machine, this is because i found some white plastic doorframe draught excluders with semi circular white rubber ends (designed to be crushed when a door closes called bryseal stormguard I cut off the end and middle bits so it's usable under the bezel) I used this to hold the tinted 3mm perspex in place and is not attached to anything so if i gently pull out this strip I can easily remove the perspex for dusting or cleaning without having to remove any screws.
I still have the artwork files but they are 10meg each so are too big to post here if anyone wants them or knows a way to post them somewhere let me know.
« Last Edit: August 27, 2012, 05:25:23 pm by agent_c »
  • Last login:Today at 07:21:04 pm
« Reply #20 on: August 27, 2012, 05:48:14 pm »
If you want to post them for everyone to share, the Arcade Art Library is a great choice.
Click on the appropriate category and look on the upper-right side for the upload button.
griffindodd
  • Builds Stuff
« Reply #21 on: August 27, 2012, 05:54:30 pm »
I really love the color scheme of this cabinet, very fresh and clean, much lighter than the usual cab colors, great job!!!
I drink and I know things.
agent_c
« Reply #22 on: August 28, 2012, 01:00:35 pm »
Thanks Scott,
   I uploaded them and got the awaiting moderater message so hopefully they will be up there soon.
« Last Edit: November 20, 2021, 06:24:32 pm by agent_c »
