Author Topic: Which 64-bit OS do you guys run for mame?  (Read 3164 times)
nitz
  • Last login:November 24, 2015, 07:57:29 pm
« on: August 22, 2012, 10:03:02 pm »
WinXP or Win7?
I'm leaning toward WinXP since I was able to locate a 64-bit stripped down version, but wondering if there would be any advantages to being more current and using Windows 7. Can't seem to find a stripped down 64-bit version of it though.
So what are you guys using?
yaksplat
    • Random Projects
Re: Which 64-bit OS do you guys run for mame?
« Reply #1 on: August 22, 2012, 10:42:19 pm »
i use win7 x64 on everything.  Main reason for me is I like using win7 a hell of a lot better than xp to use. I honestly can't stand using xp anymore.
http://yaksplat.wordpress.com
Nightbring3r
  • Last login:February 25, 2023, 04:27:31 pm
« Reply #2 on: August 22, 2012, 11:51:03 pm »
Win 7. XP 32bit is great but XP 64bit isn't.
  • Last login:February 15, 2026, 01:44:40 pm
« Reply #3 on: August 23, 2012, 02:32:56 am »
You are talking about on a cab right?
Xp 64 all the way.  Win 7 takes up too much resources and it has issues with unsigned drivers and all manner of minor annoyances.  Win 7 is a better OS all the way around, but when you are building a cab you don't need any of it's improved features.
Also for the record, win 7 64 bit is the superior version, the 32 bit version is identical to the 64 bit only.... wait for it.... more bits!  ;)
Yenome
  • Last login:November 14, 2025, 04:36:28 am
  • Punch a fish. Make a wish
« Reply #4 on: August 23, 2012, 04:08:53 am »
i agree with everything in the post. winxp 64bit if your just using it for a cab. no sense in the extra bloat when it wont be used. if i hadnt left the code attached to the pc case i gave my bro i would be installing 64bit xp on my mamepc now.
nitz
« Reply #5 on: August 23, 2012, 11:56:45 pm »
Yep, it's for a cab, so XP64 bit it is then.
Thanks guys! :cheers:
amheck
  • Last login:February 20, 2015, 01:13:41 pm
« Reply #6 on: November 20, 2012, 09:50:09 am »
Are you guys aware of any guides that let you take a fresh Win7 install and trim it down to remove all of the unnecessary services and whatnot?
« Reply #7 on: November 20, 2012, 10:04:43 am »
Doesn't really remove anything, but disables a lot of stuff:
http://www.blackviper.com/2009/10/01/black-vipers-windows-7-super-tweaks/
A lot of people post here with problems caused by using TinyXP or MicroXP (and usually fail to mention they aren't using a full windows build).
IMO, it's better just to disable the services.  The effect is the same, but they are still there if needed.
thaddeussmith
  • Last login:April 21, 2017, 11:49:51 am
« Reply #8 on: November 20, 2012, 11:25:03 am »
i'm running win7 x64 on a dual core AMD (~3ghz) with absolutely no issue. If you're running modernish hardware there is no reason to waste your time with XP.
Coru
  • Last login:March 19, 2013, 05:22:51 pm
« Reply #9 on: November 23, 2012, 04:43:36 pm »
i used windows xp 64 bit a stripped down version and i personally havent had any problems.
Yenome
« Reply #10 on: November 24, 2012, 12:10:43 pm »
win7 is not as easy to hide as XP is. plus the higher overhead of win7. and there is more tweaks and programs in general written for XP that may or may not work on win7. tho atm i run win7 on my htpc which is also doubling as my arcade pc.
thaddeussmith
« Reply #11 on: November 25, 2012, 03:42:38 pm »
i am fortunate then, that I'm not concerned about completely hiding windows and that my dual core AMD reduces any concerns about OS overhead. I also run vanilla MAME and MaLa. I guess I'm the minority though.
