February 06, 2026, 10:21:56 pm
First off, Hoopz is right.
Top Gun was cheesy?
Quote from: Gray_Area on August 22, 2012, 04:41:55 pmTop Gun was cheesy?Not if your into dudes.
Quote from: Howard_Casto on August 23, 2012, 02:58:14 amQuote from: Gray_Area on August 22, 2012, 04:41:55 pmTop Gun was cheesy?Not if your into dudes. LOLYOUFAILED
Quote from: SNAAKE on August 24, 2012, 01:20:15 amQuote from: Howard_Casto on August 23, 2012, 02:58:14 amQuote from: Gray_Area on August 22, 2012, 04:41:55 pmTop Gun was cheesy?Not if your into dudes. LOLYOUFAILEDNope still won. Also, says the guy who types his reply without spacing in all caps. Bad grammar doesn't change the fact that liking Top Gun a little too much means you are probably into men.
Quote from: Howard_Casto on August 24, 2012, 10:14:12 pmQuote from: SNAAKE on August 24, 2012, 01:20:15 amQuote from: Howard_Casto on August 23, 2012, 02:58:14 amQuote from: Gray_Area on August 22, 2012, 04:41:55 pmTop Gun was cheesy?Not if your into dudes. LOLYOUFAILEDNope still won. Also, says the guy who types his reply without spacing in all caps. Bad grammar doesn't change the fact that liking Top Gun a little too much means you are probably into men.Also doesn't change the fact that nobody really gives a ---fudgesicle---... except maybe for you.
Quote from: SavannahLion on August 25, 2012, 12:14:48 pmQuote from: Howard_Casto on August 24, 2012, 10:14:12 pmQuote from: SNAAKE on August 24, 2012, 01:20:15 amQuote from: Howard_Casto on August 23, 2012, 02:58:14 amQuote from: Gray_Area on August 22, 2012, 04:41:55 pmTop Gun was cheesy?Not if your into dudes. LOLYOUFAILEDNope still won. Also, says the guy who types his reply without spacing in all caps. Bad grammar doesn't change the fact that liking Top Gun a little too much means you are probably into men.Also doesn't change the fact that nobody really gives a ---fudgesicle---... except maybe for you. And you apparently, and the two or three other people who have responded to my comment. If you guys didn't give a ------- then you wouldn't have responded.
