Author Topic: Help driver calamity for new ati radeon 4350  (Read 3985 times)
weron44
  • Last login:September 02, 2012, 09:58:28 am
« on: August 17, 2012, 05:52:37 am »
Hi,
I have a new sapphire radeon 4350 hd . When I try to install the driver crt_emudriver_9.3_1.2a_xp32_multisync, I have this error:  "Setup didn't find a driver compatible with your current hardware or operating system. Setup will now exit."
My Hardware ID is:
PCI\VEN_1002&DEV_9553&SUBSYS_3092174B&REV_00
PCI\VEN_1002&DEV_9553&CC_030000
Thank you very much and sorry for my poor english.
androtaz08
  • Last login:October 09, 2024, 07:17:01 am
Re: Help driver calamity for new ati radeon 4350
« Reply #1 on: August 17, 2012, 07:39:40 am »
you have to mode the driver. I had the same issue with my 4350 its actually a mobility card.
weron44
« Reply #2 on: August 19, 2012, 05:31:34 pm »
Hi,
for my problem, I modified the files as the topic : http://forum.arcadecontrols.com/index.php/topic,120690.0.html
the hardware is similar. Apparently it works  :notworthy:
if still someone could check if the files are good  ;)
thanks
weron
  • Last login:March 15, 2026, 04:39:26 pm
« Reply #3 on: August 20, 2012, 12:03:02 pm »
Your files look fine. Good job!
