Author Topic: New J-Pac. Having problems  (Read 1318 times)
fatsgt
  • Last login:June 29, 2015, 12:22:01 am
  • Taito Type X, I hate you.
« on: August 14, 2012, 11:45:32 pm »
I recently decided to revive my old Mame machine I built nearly 10 years go. I bought a new J-pac to run the controls but I'm having issues.
- Problem. None of the buttons or joysticks connected to the Jamma harness are working
- The extra buttons I have wired directly to the J-pac DO function.
Things to note.
- When I plug in the J-pac I get a shot flash followed by a steady which should mean all is well.
- I'm not connecting a monitor to the J-pac.   I'm just using a laptop for testing
- I don't have a cabinet right now. I'm running everything with the control panel I took off the cabinet which has Jamma harness, an opti-pac and a J-Pac.
- The controls were all contented and functioning properly at one time.
- I don't have a power supply of any kind connected to the Jamma harness.
I think it may be something with the Jamma ground but It's been awhile and I'm not sure how I should ground everything.
Any ideas?
MTPPC
Re: New J-Pac. Having problems
« Reply #1 on: August 15, 2012, 11:07:52 am »
It sounds like you need to connec pin 1, pin 2, pin A or pinB to the control panel.
To test you could use a jumper wire and short pin A to pin Z to see if the letter 'a' is output. This is player2 button 1. You could do the same thing for pin 1 to 22, but the output would be 'left control'. Use winIpacIPD software in test mode to see if you are making connections.
http://www.ultimarc.com/winipac_ipd.html
http://pinballmd.com/
fatsgt
« Reply #2 on: August 16, 2012, 04:24:12 pm »
Thanks for the direction!  I finally got things to work by running a wire from pin 1 to the ground on one of the player 1 buttons. Now I just need to figure out how to correctly ground this sucker.
Any idea how/where I need to do that?
Thanks again,
