Author Topic: RGB Pushbutton Showdown!!  (Read 35129 times)
saloonstudios
  • Last login:August 08, 2018, 12:09:13 am
Re: RGB Pushbutton Showdown!!
« Reply #40 on: March 28, 2013, 02:49:49 pm »
I'm necro'ing this thread because it seems so thorough already...
Will the UILA LED fit into the Sanwa OBS(F/C)30? I've never seen Semitsu buttons in person so I don't know if they're similar to the Sanwas.
armi0024
  • Last login:January 12, 2023, 09:57:36 pm
« Reply #41 on: March 28, 2013, 09:57:25 pm »
Yes they will, we are also working on a new design....
thatpurplestuff
« Reply #42 on: March 28, 2013, 11:46:40 pm »
Missed this thread the first time around, but there's some awesome info here.  Thanks!
armi0024
« Reply #43 on: March 28, 2013, 11:48:41 pm »
We may have to see if we can get Jace to review the new lights.... :)
« Reply #44 on: March 29, 2013, 12:26:08 am »
Looking forward to this!
saloonstudios
« Reply #45 on: April 12, 2013, 12:04:01 am »
Today I learned the hard way that the Uila's in fact do NOT fit into the Sanwa buttons without doing some modifications to shorten the plunger. Just throwing that out there-
armi0024
« Reply #46 on: April 12, 2013, 03:12:01 am »
The Uila S should fit if you line RGB leds up with the open spot in the plunger.  The Uila S flash can fit the same way, however you may need to take modify the back of the latch on the plunger depending on the solder for the flash lamp.
edekoning
« Reply #47 on: April 12, 2013, 07:31:50 am »
When will the Uila budgets be back in stock? I've been waiting for four months now! I've been in contact with Susan about it, but after her last email (March 22) I have not heard back from her anymore. I really want to finish my control panel  :)
saloonstudios
« Reply #48 on: April 12, 2013, 09:21:31 am »
Yeah the Uila S is what I have, I lined up the LED in the gap, but the issue is mostly that the pcb itself is too thick to allow the plunger to compress the switch cleanly. I need to sand down the perimeter of the plunger to compensate for the space the pcb takes up.
chito
  • Last login:July 23, 2023, 12:29:26 pm
    • forum.arcadecontrols.com/index.php/topic,151843.0.html
« Reply #49 on: September 15, 2016, 11:10:18 pm »
how do you install pele rings?
at first i thought it was inbetween the control panel and the nut... but the nut gets in the way... there is no room for it especially if the led is meant to be up against the button. the only images i could find was a stick that hot glued them in place.... dont think thats how they are meant to be installed
http://forums.shoryuken.com/discussion/75228/check-out-my-new-arcade-stick-no-image-quoting/p516
armi0024
« Reply #50 on: September 15, 2016, 11:12:21 pm »
Depends on what you are using them with.  On IL buttons the should go between the nut and cp.
-Bryan
chito
« Reply #51 on: September 15, 2016, 11:50:24 pm »
yeah its for IL buttons. I tried in between the nut and cp and after forcing it a bit, it fit.
Looking at the way the leds sit would mean that the light bleeds into other buttons if they are lit up as different colours? Whats the most effective way to handle this?
« Last Edit: September 16, 2016, 04:51:40 am by chito »
