Author Topic: Mame conversion of a Pole Position cabinet  (Read 6452 times)
mappler
  • Last login:September 04, 2012, 08:29:19 pm
« on: August 12, 2012, 10:55:21 am »
I have acquired a non-working Pole Postion cabinet that I am planning to use for a MAME conversion.  I would very much like like to keep the existing driving controls intact, but find some way to add a more traditional control field above them to play non-driving games.  I've searched around looking for anyone who has already done this, but have only found mods that removed the existing steering wheel and added a new control panel.  Is anyone aware of any designs that have done what I am looking for?
Thank you in advance,
 M
  • Last login:Yesterday at 12:24:02 am
Re: Mame conversion of a Pole Position cabinet
« Reply #1 on: August 12, 2012, 12:05:54 pm »
Just me thinking out loud, but the wheel takes up so much real estate that I think it would probably feel awkward reaching over them to play games. I say you should try and see if you could trade that PP for a more traditional cabinet. Just my two cents.  :cheers:
Ken Layton
  • Guru
  • Technician
« Reply #2 on: August 12, 2012, 01:35:08 pm »
This guy did one:
mappler
« Reply #3 on: August 12, 2012, 01:41:02 pm »
Yeah, I saw that video.  He left it as a driving game only MAME machine though.  He didn't add additional controls.
compute
  • Last login:February 26, 2018, 05:33:36 pm
« Reply #4 on: August 13, 2012, 08:17:13 am »
I think some engineering is in order.  Why not make the wheel removable and put an aircraft carrier on the front?  Or switchable panels?  Why not have one or the other pull down?  heck, you could have the wheel flip up from a recessed position.  It'll look goofy to a PP purist, but it'll work.
mytymaus007
« Reply #5 on: August 13, 2012, 08:36:21 am »
im all for hot swap panels! :cheers:
mappler
« Reply #6 on: August 13, 2012, 08:55:42 am »
I like the "flip up" idea.  I did a little tinkering and measuring and it looks like that would work.
I think I can fit a stack (from bottom to top) of a keyboard tray, then the steering wheel/gear shifter mechanism (flipped down flat), and then a control panel with joysticks/buttons, etc.  The top panel would be removable and the wheel/gear shifter can flip up.
I think I'll mock something up and see if it will work the way I am thinking.  I am absolutely thrilled about getting this Pole Position cabinet.  I know a lot of people would not consider this cabinet "ideal" for a MAME conversion, but for me, it brings back a lot of memories.  I put a lot of quarters in PP and PP2.   The cabinet artwork is just awesome.
 -Matt
mytymaus007
« Reply #7 on: August 13, 2012, 11:10:16 am »
Y not make it a driving cab and get another for everything else
mappler
« Reply #8 on: August 13, 2012, 02:06:30 pm »
Only room for one cabinet..;)
« Reply #9 on: August 13, 2012, 03:25:54 pm »
I have a PP cab, it'd be terrible for anything other than a driving machine without a buncha work to the CP area. (cept maybe a shooting cab)
TGov
  • Last login:March 21, 2017, 02:07:54 pm
« Reply #10 on: October 03, 2012, 01:21:40 pm »
I just picked up a PP cab and I think my brother is going to MAME it.  There is a ton of room for CP controls and also room for a 27" CRT in there.   Should be a pretty good MAME cab.
« Reply #11 on: October 03, 2012, 01:49:56 pm »
theres JUUUUUUUST enough room for a 27"
« Reply #12 on: October 03, 2012, 04:10:43 pm »
Only room for one cabinet.. ;)
I have one too.  It only makes a good MAME cab if you remove the wheel entirely.  That wheel is way too big to share the CP with anything else.  With no wheel you could make a decent mame cab out of it so long long as you don't stick 500 buttons on it.
cw
  • Last login:May 03, 2025, 09:26:58 pm
  • Game over man game over
    • The Cab
« Reply #13 on: October 03, 2012, 05:06:45 pm »
I have a pp that needs a home here in Austin Tx... not a bad looking shell... and it solid.
paigeoliver
  • Awesome face!
« Reply #14 on: October 03, 2012, 06:40:55 pm »
Have one available in St. Louis as well.
TGov
« Reply #15 on: October 03, 2012, 07:52:10 pm »
Ya we are not going to use the wheel on it, but he is keeping the pedal I think to use with a spinner for the few racing games he will want to play.  If he doesn't use it I will in my cab.
TGov
« Reply #16 on: October 03, 2012, 07:52:51 pm »
Was that a TV or an Arcade monitor?
willybeamish
  • Last login:December 22, 2014, 01:59:10 pm
« Reply #17 on: October 04, 2012, 09:07:16 am »
Ive got a PP cab myself but im making it a MAME only cab. I do have the original pedal but I dont think ill be using it. Good luck
Currently rebuilding a PP cab and converting it to a mame cab..view the progress here http://forum.arcadecontrols.com/index.php/topic,122815.msg1305024.html#msg1305024
