Author Topic: Radeon x550 + crt tv Trilux 29''  (Read 3534 times)
djcasey
  • Last login:August 24, 2025, 06:07:43 pm
« on: August 10, 2012, 04:53:44 am »
hi
have few question
i have radeon x550 on my cab, conected to crt tv via scart, it works well in soft 15khz
only problem i have is screen flickering during play movies in olkd games like tomb raider or c&c (itro etc)
is instaling custom drivers will solved this isue ???
and second i tried this driver few weeks ago, it installs ok but i must do smg wrong because i have only 256 colors
have some time today and i would like to tried  it again
what i need to do to install it corectly ??
my radeon have to outputs dvi and vga, now im using vga + soft15khz
but i hear that i need to use dvd + converter to vga to works ok with custom drivers, is it right ??
  • Last login:March 08, 2026, 10:43:40 am
Re: Radeon x550 + crt tv Trilux 29''
« Reply #1 on: August 10, 2012, 01:53:12 pm »
Hi djcasey,
DVI to VGA is only necessary for newer cards where the DVI is the primary output, I'd say that's not the case with the x550, however as long as you get picture at all then it means that's the right output.
As for the drivers installation, make sure you run CatUninstaller booting in safe mode to get rid of all trace of ATI software, then reboot normally and proceed with normal installing.
Try both 6.5 and 9.3 versions, in case that was the issue. If the problems persist, send me your video card's hardware IDs.
I don't believe the flicker in the movies will get fixed by this drivers, anyway.
djcasey
« Reply #2 on: August 10, 2012, 03:15:42 pm »
thx for answers
i have small hope for fixing flickering ;p
is all emulator take advantage from custom drivers or just only groovemame, cabmame ??
pls guide me if im doing instalation properly...
uninstalling drivers
reboot
installing custom drv
reboot
what i need to do to gave You video card's hardware IDs. ??
what else ?? do i need setup smg ?
