Author Topic: Dissassembly IL compact Joystick  (Read 1818 times)
kluber
  • Last login:September 20, 2012, 05:07:49 pm
« on: August 07, 2012, 06:05:53 pm »
Hi,
anyone knows how to dissassembly an IL compact Joystick, its rusty and needs to be clean and I need to change the acrilic of the CP.
  • Last login:Today at 06:48:03 pm
Re: Dissassembly IL compact Joystick
« Reply #1 on: August 07, 2012, 06:36:55 pm »
Welcome aboard, Kluber.
The IL Compact is pretty much the same as a Happ Super.
Here is the exploded view.
Carefully pop off the clip (lower left corner) since it may go flying across the room.
The rest of the disassembly should be fairly straight forward.
kluber
« Reply #2 on: August 07, 2012, 06:55:11 pm »
thank, i've managed to disassemble one, after 2 hours  :badmood:
The rust was so getting in the way that I couldnīt see the clip on the bottom.
One to go...
