November 01, 2025, 02:16:21 am
Home
Help
Search
Login
Register
News:
Support this site
Shop
Amazon Arcade Stuff
through our link. Thank you!
Well, that was weird. Outage sorted out. Thank you SirWoogie for saving the day!
Main
Monitor/Video Forum
Sharp image 629 ds-r on and off sound
Main
Restorations
Software
Audio/Jukebox/MP3
Everything Else
Buy/Sell/Trade
Project Announcements
Monitor/Video
GroovyMAME
Merit/JVL Touchscreen
Meet Up
Retail Vendors
Driving & Racing
Woodworking
Software Support Forums
Consoles
Project Arcade
Reviews
Automated Projects
Artwork
Frontend Support Forums
Pinball
Forum Discussion
Old Boards
Raspberry Pi & Dev Board
controls.dat
Linux
Miscellaneous Arcade
Wiki Discussion
Old Archives
Lightguns
Arcade1Up
Try the site in https mode
Site News
Unread posts
New Replies
Recent posts
Rules
Chatroom
Wiki
File Repository
RSS
Submit news
« previous
next »
Send this topic
Print
Pages: [
1
Go Down
Author
Topic: Sharp image 629 ds-r on and off sound (Read 1831 times)
GMZombie
Trade Count:
0
Full Member
Offline
Last login:March 22, 2022, 10:11:23 am
I am a living Legend who fixes stuff... mostly
on:
July 28, 2012, 08:16:47 pm »
ok i have this chassis and when it is hooked up it seems to be trying to start but i can hear a light chirp on off on etc. im pretty sure that would indicate a fault at the hot but what i need is a schematic of the chassis. does anybody have this.
Logged
GMZombie
Trade Count:
0
Full Member
Offline
Re: Sharp image 629 ds-r on and off sound
Reply #1 on:
August 09, 2012, 09:41:41 pm »
nobody has a schematic for this chassis or knows where i can get one?
Logged
GMZombie
Trade Count:
0
Full Member
Offline
Reply #2 on:
August 24, 2012, 11:58:38 am »
:burgerking:ok went ahead and replaced the hot. Same problem. So I started to check voltages and it seems I get 168v up to c814 on. The side that comes from the ad input. On the otherwise I get about .2 volts dc. This is Tue only point I can see that goes from the power supply side to the other side of Tue board besides the transformer. I checked voltage st the hot and I have none or so minimul u couldn't count it. When u check the voltage at the collector at the hot I notice when I hear the overload of the hot on the meter for a second it will go o/l then back to low volts. Checked at the b+ adjustment pin and it shows 169volts dc. I'm stumped
Logged
GMZombie
Trade Count:
0
Full Member
Offline
Reply #3 on:
September 06, 2012, 07:21:23 pm »
nobody can help me with this multi cga/ega chassis?
Logged
mgb
Trade Count:
0
Full Member
Offline
Last login:August 03, 2025, 07:25:14 pm
North East, US
Reply #4 on:
September 06, 2012, 08:49:41 pm »
usually a light chirp indicates a blown flyback (which very well may have also taken out the HOT)
Logged
http://forum.arcadecontrols.com/index.php?topic=108784.0
GMZombie
Trade Count:
0
Full Member
Offline
Reply #5 on:
September 06, 2012, 09:51:04 pm »
so is there tests i can do to verify if it is a blown flyback?
Logged
mgb
Trade Count:
0
Full Member
Offline
North East, US
Reply #6 on:
September 07, 2012, 12:20:33 am »
Not really, ussually it will have a visible crack.
some times if you run it in a dark room, you may see arcing come from the flybacks body.
Logged
GMZombie
Trade Count:
0
Full Member
Offline
Reply #7 on:
September 26, 2012, 06:21:01 pm »
so here is a pic of the back of the board. i have written where i took some voltage levels and they all seem to be around 170 vdc. the only thing is after the transformer i dont have any volts and after that cap that i have indicated. could this just be a faulty flyback or should i try to replace this cap first.
Logged
Send this topic
Print
Pages: [
1
Go Up
« previous
next »
Main
Monitor/Video Forum
