Author Topic: Added buttons for Arcade  (Read 1629 times)
daruble
  • Last login:August 24, 2013, 06:23:58 pm
« on: July 21, 2012, 04:53:03 pm »
Ok my name is Dave and yes I know happ has a program that helps design your control panel. But I am working on my first arcade and I am trying to figure out what I need in the way of controls. I am running Hyperspin, Mame, Atari 2600/5200/7800/Jaguar, Nintedo all of them, Sega all of them, and Mattle Intellivison. But my question really is how do I fit all of this on the Control Panel. I mean I have to be able to navigate Hyperspin and be able to play the games with the controls I install right. I am planing on this being two player control panel only and then use Xbox style for players 3 and 4
So what I am considering is trying buy most of the odder controllers like the Intellivison or atari's paddles in a USB connection. I have seen a few available online on www.retrozone.com and http://www.dascheap.com/retro-classic-games.html Then I will add a USB hub some where on my arcade that way I could also use this for PC sterring wheels perhaps.
I was considering for the rest of the consols like Nes, super nes, n64, Segas and other I would use the XBox 360 wirless PC connection.
I really want to know what buttons people have added on their own control panels that help you work with in mame or find use full do you have a volume control? Mute? Suggestion of what you wish you had put on the control panel mayeb
I have bought the following so far :)
Mag-Stik Plus
Worlds only Magnetically Centered Joystick!
 4-8 Way Switchable from top of the panel.
 The Mag-Stik is not centered by a spring but using an internal magnet. A light action gives the ultimate in joystick feel and sensitivity.
Also switches from 4 to 8 way mode from the top of the panel!
 This is the only joystick in the world which can be switched over from 4 to 8 way from the top with no lever or other unsightly intrusion. Keeps the panel arcade-real but still gives the ability to play all 4 or 8 way games with the true feel of the correct mechanically-limited stick.
 To switch: Pull out the stick against the spring pressure, continue pulling while rotating, until the mechanism engages, then turn anticlockwise for 8-way, or clockwise for 4-way. The stick clicks into position when turned 45 degrees. The mechanism actually rotates an internal restrictor plate and also rotates the microswitch actuator for a perfect 4-8 way transition.
Happ Green 8-Way controller
Description                Quantity            Unit price    Amount
Green buttons               10                    $1.59      $15.90
Purple buttons                5                      $1.59       $7.95
Red Buttons                   3                      $1.59       $4.77
1 player                         1                      $2.05       $2.05
2 player                         1                      $2.05       $2.05
white buttons                 5                      $1.59       $7.95
black buttons                 2                      $1.59        $3.18
Orange buttons              1                      $1.59        $1.59
Thanks for any replys and help
Ginsu Victim
  • Comanche, OK -- USA
Re: Added buttons for Arcade
« Reply #1 on: July 21, 2012, 04:56:08 pm »
Take a look at this thread to see what others have done:
http://forum.arcadecontrols.com/index.php?topic=59359.0
Avoid trying to cover too much. Set it up to play as much as you can without being overly complicated. If it just confuses your guests, you've done it wrong.
« Last Edit: July 21, 2012, 04:58:36 pm by Ginsu Victim »
