Author Topic: Stripping and Painting  (Read 1048 times)
null
  • Last login:January 13, 2004, 04:00:53 pm
« on: October 06, 2003, 03:08:57 am »
I recently purchased a 1989 "Buster Bros" arcade machine off ebay with hopes of converting it to a MAME machine. The paint job is horrible on the machine and it looks like it was another machine before it became a Buster Bros. What would be the best way to strip the paint off the machine to get to the bare wood and then the best method to re-paint it? I've heard of both methods of sanding the machine or using chemicals to strip, I was wondering if anyone has had experiences (pros and cons) of using one of these methods.
Thanks in advance,
null
paigeoliver
  • Awesome face!
Re:Stripping and Painting
« Reply #1 on: October 06, 2003, 03:26:51 am »
I have done both. You will never manage to sand off all the old paint. I tried that with a cabinet once and I never got down to bare wood. But you can sand down enough where you will have a nice paintable surface (maybe, unless it has 8 or 9 coats of paint).
The last time I did this I used a gallon can of paint stripper. The NASTY stuff that you have to use outdoors and wear rubber gloves with. It worked like a charm. It stripped the cabinet great, and then I proceeded to use wood stain on it rather than paint it again (dings, dents, and little scratches don't really show up on stripped and stained plywood cabs, so it is a good choice of finish). I may have clearcoated it afterwards. I don't really recall now (and the machine is long sold). I certainly clearcoated SOMETHING around that time period, but I don't THINK it was that cabinet, because I am still on a can of clearcoat I have had for years. Must have been something else. Ok, I am rambling now.
Yes, you are right about your Buster Bros. There is no such thing as a dedicated Buster Bros machine. Capcom never really was into dedicated cabinets much, almost all their games were conversion only, and even their dedicated games were still available as kits, and the kits outsold the dedicated versions handily.
Post a picture and I will tell you what it is.
Also, if the machine still has sideart, then just paint around it. Resulting cabinet will be worth more than if you had ripped the sideart off.
Finally, if you have a set of NOS sideart to use, then you wouldn't believe how great sticker sideart looks on sanded and lightly stained plywood. I have no idea why more games didn't come like that.
« Last Edit: October 06, 2003, 04:36:58 am by paigeoliver »
Apollo
    • Eight Bells
« Reply #2 on: October 06, 2003, 04:28:44 am »
I agree with paige you've got to use chemicals, just make sure you dispose of the waste properly please, it's pretty toxic stuff.
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
« Reply #3 on: October 06, 2003, 03:42:16 pm »
Dissapointed... this thread had nothing to do with hot chicks and dancing poles...
rampy
