Author Topic: Daphne in Mala for dummies?  (Read 7397 times)
narwhalsRus
  • Newbie
  • Last login:August 08, 2012, 02:55:53 pm
« on: July 16, 2012, 04:46:50 pm »
Hey guys,
So my cab is built and ready to go. But I've been trying so hard to get Dragon's Lair up and running to no avail. I'm the most confused person right now...
How do I make batch files? Frame files.. what are those? I'm lost. The question I have for you dudes and dudettes is does anyone have lovely, idiot-proof, step-by-step instructions for running Daphne (and Dragon's Lair) in Mala? I would be forever grateful.
THANK YOU!!
Edit: Yes, I've read UncleT's doc. Still confused.
Wade007
  • Last login:April 06, 2017, 01:33:35 pm
  • A MAME cabinet at home is heaven
    • bit.ly/1cWnoIC
    • Cheapskategamer.com
Re: Daphne in Mala for dummies?
« Reply #1 on: July 16, 2012, 05:13:10 pm »
You have several questions here. Each has an answer and yes, Daphne runs fine on Mala.
A batch file is a short command file used to launch Daphne with Mala since Daphne does not have a command line interface.
See my post here (3rd one down) for more info on Daphne Batch files: http://forum.arcadecontrols.com/index.php?topic=121260.0
I can send you the EXACT code later.
Use Daphne launcher first to get Dragon's Lair, etc working WITHOUT a batch file and WITHOUT Mala. Then build a batch file that will launch WITHOUT Daphne launcher, then integrate the launch of the batch file into Mala. I can send you screenshots later or keep searching these forums.
Getting Frame files to work comes WAY before a batch file. Frame files tell Daphne how to load mpeg/video. Configure Daphne loader to load the frame file, the frame file loads the mpeg or video file(s). This part is basic to running the emulator. Get this working FIRST before you start worrying about batch files and Mala. You may need to google "how to set up Daphne" first, then come back here for help with Mala.
You may want to consider these links:
You will need 3 things beyond the Daphne emulator to run the games; roms, framefiles, and mpeg (or other video). The toughest of the three are the mpegs (video). Unlike MAME, Daphne roms are easy to find and use. You can write your own framefiles if needed. Video is the true copyrighted data.
That's the order of operations, I'm at work right now and not in front of my cabinet system, so I can't help you any more right now, but I can show you more details if needed. I'm here to help, but you have several levels of coding to work out.
« Last Edit: July 16, 2012, 06:26:49 pm by Wade007 »
My Super Arcade cabinet project:
Software blog article: http://bit.ly/1cWnoIC
Hardware blog article: http://bit.ly/1dWxjvP
YouTube video: http://bit.ly/1N818Xm
Super Arcade Cabinet Progress thread (Now Complete):
http://forum.arcadecontrols.com/index.php/topic,123292.0.html
Frontend Video Intro: http://bit.ly/1P9HPDN
Gray_Area
  • -Banned-
  • -Banned-
« Reply #2 on: July 18, 2012, 06:09:35 pm »
The reason the tutorial is confusing is, I'm guessing, you have little to no experience with directory trees and command line. Otherwise, and you don't need very much to get by, it's actually simple pimple.  Don't look for any 'whys', just look at what does happen, and copy it. Now, I'm sure one totally mystifying thing is the "<....>". What does that mean? Do I type rom, etc in there? Depends on the circumstance. Another thing: do I set up my directories exactly like UncleT shows or it won't work? No, and hell no I don't. (I have three emulators, and I like to keep them totally separate.) But you can.
Daphne, except for the Digital Leisure stuff, is totally self-sufficient. You download the package and run it. Everything happens for you. Getting Mala to run it is very simple. Make sure you read the latest version of the tutorial (1.8 I think), as there are additions and refinements.
« Last Edit: July 18, 2012, 09:32:26 pm by Gray_Area »
-Banned-
