Author Topic: 7 button question  (Read 2207 times)
soslo
  • Last login:March 10, 2012, 03:23:36 pm
  • The Governator
    • My website does not have a name yet
7 button question
« on: October 05, 2003, 08:08:26 pm »
On my last CP, I had my 6-button layout wired like this:
456
123
I am now making a 7 button CP (top 3 buttons are black, and the bottom 4 are like neo-geo).  How should I wire them up? Which button gets repeated?
Example:
 456
1234
5 MAME cabs and counting...
Ever wonder what full side art looks like?
http://www.aaronmurray.com
cdbrown
  • Last login:October 16, 2017, 09:52:03 pm
  • Bowowow
Re:7 button question
« Reply #1 on: October 05, 2003, 09:19:47 pm »
Many people have there layout like
  5 6 7
  2 3 4
1
And have button 1 and 7 wired together.  The thing to remember is if you've got a group of 6 buttons each of them should be wired differently, it's that extra neogeo button that can be wired with a button on the top row.
Good luck
soslo
  • The Governator
« Reply #2 on: October 05, 2003, 09:24:10 pm »
with the layout you just mentioned, it looks a little crazy for SF type games...or perhaps my understanding of the button numbers is off. I am thinking in terms of IPAC wiring.
I use buttons 7 and 8 for both players as admin buttons (pause, escape, menu, select)
cdbrown
  • Bowowow
« Reply #3 on: October 05, 2003, 09:33:52 pm »
Sorry mate - I just numbered those buttons without the wiring
So if I do it again
   4 5 6
   1 2 3
6
Or a different way
  1 2 3
  4 5 6
1
Just remember have your 6 SF buttons wired to spots 1->6, then that extra button on the bottom line (be it on the left or right of the SF buttons) wire that to the same IPAC spot as one of the buttons on the top row.  It doesn't really matter which one.
This is where ctrlr files are very important.  You can wire it up any way you want and you assign which buttons do what in the ctrlr files.
I hope that's clearer - if not shout.
soslo
  • The Governator
« Reply #4 on: October 05, 2003, 10:37:18 pm »
much clearer - thanks!
Hellfromabove
  • Last login:January 08, 2020, 05:45:41 pm
  • Soundwave Superior, Constructocons Inferior!
« Reply #5 on: October 06, 2003, 12:47:16 am »
Actually I made a cemetric layout. When you print it out (which you can on a regular printer) the holes will be the exact drill sizes. Also on th left it has a joystick mounted with exact place to drill for stick and places to drill for the carriage bolts. I'll post it later since it's not on this comp. Thanx.
-See Ya!!!
2slk
  • Last login:February 27, 2004, 11:38:09 pm
  • Fascinating, Captain.
« Reply #6 on: October 06, 2003, 09:32:05 am »
 I think you can wire the buttons however you want (with the exception of hardwiring two buttons to the same encoder connector) and just use the MAME ctrlr files to change how MAME interprets them.  Don't ask me exactly how to do it because my cab isn't completed yet. I think SirP does it that way though.
Hellfromabove
« Reply #7 on: October 06, 2003, 08:17:08 pm »
Here's that layout I made that I promised, hope you like:
Thanx.
-See Ya!!!
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #8 on: October 07, 2003, 01:47:41 am »
Shhhh.... Don't tell them that; it will just confuse them.   ;)
Robin
Knowledge is Power
  • Online Online
  • Last login:Today at 01:32:52 pm
« Reply #9 on: October 07, 2003, 02:04:51 am »
No joke don't tell them that. :)
It's important to get your layout right in the hard-wired sense first and then turn to software on special cases.  Remember you can mass-redefine easily for mame, but not for other emulators.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #10 on: October 08, 2003, 12:00:53 am »
I meant it as a joke, and still do.  I left out a part to keep down the confusion.  Here's that part:
The best reason to hardwire the physical button1 to the ipac port labeled button1, which is by default "left_ctrl", which is the default mame button1,  is so you don't get confused when you hear or read the term/label "button1".  Hence my "don't tell them.." joke.
OTOH, the Ipac, as most CP encoders, can be remapped for that all emu "mass-redefine".
For example, the mk64 encoder instructions say (paraphrased): hook up the wires any way to want (except for ground, and the rotary, shift button and LED exceptions if you use them), and then use the encoder software to reprogram the encoder to output what you want each button/direction to output.
Yes, it's more work to reprogram the ipac than not to, but it's not all that much more. [shrug]
True, it is easier and less confusing to just wire it the way it's labeled and ignore many of the encoders' features, and for us helpers to pretend that that's the only way.  But there is more than one way, and sometimes are usefull (example: you can easily do a 3 player CP (up to 4 buttons each) with the ipac2 even though it's only labeled for 2 players).
Of course, if you only use mame, you can do as 2slk said.  (With some problems with "hardcoded" inputs, however.)
Robin
Knowledge is Power
grafixmonkey
  • Last login:October 16, 2010, 08:16:50 pm
  • must... tear self... away from... Tron...
    • My graphics/arcade/circuits site!
« Reply #11 on: October 08, 2003, 03:00:16 am »
I remapped P1B1 off of ctrl.  Same for everything that was an alt, shift, etc., because the dang things kept doing windows shortcuts.  After my panel had been working great for a week, it took me forever to figure out why Mame kept jumping from fullscreen to windowed and back when I played Turtles.  Turned out player 3 had never been used at the same time as P1 before then, and one of its buttons was 'enter' while one of P1's was 'alt'.  Grrrrr.
-- See my grafix, circuits and cab on my
-- new arcadey page:  http://www.bkgrafix.net
