Author Topic: How to identify game Windows title for AHK coding? [SOLVED!!]  (Read 3506 times)
Wade007
  • Last login:April 06, 2017, 01:33:35 pm
  • A MAME cabinet at home is heaven
    • bit.ly/1cWnoIC
    • Cheapskategamer.com
I'm coding an AHK file to close itself once "Big Buck Hunter" game closes on the PC.
Problem is, the game automatically goes full screen at launch and I can't find out the name/title of the window in which it runs so that the following code might work:
WinWait, Big Buck Hunter ; This isn't the right Window title. Don't know how to find out!!!
WinWaitClose, Big Buck Hunter
exit App
There isn't an options area in any menu launch screen whereby I can make it run windowed or lower resolution, so I can see what Windows calls the running game, so I can then in turn correctly fix the code above. The rest of my script seems to work fine. I just can't code for the situation in which Big Buck Hunter get's closed via the menu system and AHK must then close itself.
Anyone know how to find out Windows title info with a game that only runs full screen?
Thanks in advance.
« Last Edit: July 13, 2012, 03:00:03 am by Wade007 »
My Super Arcade cabinet project:
Software blog article: http://bit.ly/1cWnoIC
Hardware blog article: http://bit.ly/1dWxjvP
YouTube video: http://bit.ly/1N818Xm
Super Arcade Cabinet Progress thread (Now Complete):
http://forum.arcadecontrols.com/index.php/topic,123292.0.html
Frontend Video Intro: http://bit.ly/1P9HPDN
  • Last login:Yesterday at 11:50:38 am
Re: How to identify game Windows title for AHK coding?
« Reply #1 on: July 11, 2012, 11:31:24 pm »
CTRL+ALT+DELETE and bring up windows task manager.  ;)
RamjetR
  • Last login:July 04, 2021, 03:27:58 am
    • My Youtube Channel
« Reply #2 on: July 11, 2012, 11:41:49 pm »
I'll 2nd on A+C+D Task Manager.
Also some/most games will respond to an Alt-Enter as a windows shortcut to FullScreen/Window mode.
Ramjet
Gentlemen.... Start your engines!
My Youtube Channel http://www.youtube.com/user/ramjetr?feature=mhee
Try my RamjetM2Borderless V0.7 utility for your M2Emulator shooting games here https://docs.google.com/open?id=0B-P3wlCiYEm3RzhCZk1NcFR3blE
Try my Sega Model 2 Output Utility RamjetVR V1.4 https://docs.google.com/file/d/0B-P3wlCiYEm3VHhBMXNxZGVIQk0/edit
« Reply #3 on: July 12, 2012, 12:05:16 am »
The version of AHK that i installed came with AU3_spy.exe
Just run it and click on a window, it'll show window titles, classes, and all sorts of extra stuff that's handy for AHK scripts.
Wade007
    • bit.ly/1cWnoIC
« Reply #4 on: July 12, 2012, 09:50:29 am »
Thanks for your response guys. The AU3_spy.exe idea sounds promising. I'll try that.
I had tried Ctrl-Alt-Delete and then Task Manager before posting but that just shows the executable running, not necessarily the name of the window.
I'll try a few more things and repost. Thanks again for your help.
Wade007
    • bit.ly/1cWnoIC
« Reply #5 on: July 13, 2012, 02:59:21 am »
OK, I'm back...problem solved. Return posting here so that others might benefit.
Tried using AU3_spy.exe to get the report on the Window title AND tried Alt+Enter in game mode to try and force a windowed experience. Neither worked. The game didn't respond to Alt+Enter and I couldn't figure out how to point AU3.spy to an already active window and still see AU3.spy for the report at the same time. Maybe I was doing something wrong but it didn't seem possible to run the game AND see AU3.spy at the same time.
HOWEVER... I got some more help from an AHK expert on the AHK forum. http://www.autohotkey.com/community/viewtopic.php?f=15&t=88694&p=550621#p550621
See script below. After launching the game via the script I simply pressed Ctrl+Alt+MButton to find the game window information desired via a generated Testfile (Testfile.txt).
SetWorkingDir, C:\Arcade\PC Arcade Ports\Big Buck Hunter\BBH1
Run, C:\Arcade\PC Arcade Ports\Big Buck Hunter\BBH1\BBH1.exe
#SingleInstance, Force
SetTitleMatchMode, 2
Return
^!mbutton::
winget, winid, ID, A
WinGetTitle, wint, ahk_id %winid%
winGetClass, winc, ahk_id %winid%
IfExist, %A_WorkingDir%\TestFile.txt
   FileDelete, %A_WorkingDir%\TestFile.txt
fileappend wintitle: %wint%`n, %A_WorkingDir%\TestFile.txt
FileAppend,winclass: %winc%`n, %A_WorkingDir%\TestFile.txt
winminimize, ahk_id %winid%
run, notepad %A_WorkingDir%\testfile.txt
Return
The generated TestFile.txt reported:
wintitle: BBH
winclass: PMVsClass
I'm not sure how knowing the winclass would help me but after I plugged 'BBH' into my previous simple script everything worked perfectly!!! Case solved!!!
