Author Topic: Star wars yoke for analog drivin  (Read 2002 times)
mytymaus007
« on: July 09, 2012, 09:30:39 pm »
Just got my Star wars Yoke thanks to you guys pointing me to KLOV. Its from a fire fox which this thing is in such great condition! im so happy!! Im ready to mount it into a panel but i would like to add a shifter for driving games. again im interested in Spy hunter but also all other  racing games too. To work with most games should i get a return to center shifter with a button or since there are issues with driving games should i just use  buttons next to the yoke! Instead of a shifter especially for Spy Hunter!
Xiaou2
  • Last login:Yesterday at 08:37:37 am
  • NOM NOM NOM
Re: Star wars yoke for analog drivin
« Reply #1 on: July 09, 2012, 10:23:02 pm »
I hate return to center shifters.   They dont feel or work well at all...   However, they do beat out buttons, most especially in the case of Spy Hunter.
 You cant fumble around trying to pinpoint a button in that game.  Grasping a lever, is easy and quick.  The lever also makes it easier to be certain that you Really want to shift at that moment.  Accidental shifts would be very bad in that game, especially considering how fast the car can move in high gear.
 And again, I stress, hook an analog pedal set up to the yoke off the y-axis.  Its an easy wire job, and wont effect the standard starwars play functionality.   You might want to add a toggle switch in there anyways, just to keep any accidental y-movement from the handle, to interfere with the pedal readings on Spy Hunter / Driving games.
edit: fixed   heh   Thanks Scott.   I guess Im pretty out of it these daxs.
« Last Edit: July 09, 2012, 11:11:22 pm by Xiaou2 »
  • Last login:Today at 04:39:10 am
« Reply #2 on: July 09, 2012, 10:44:02 pm »
And again, I stress, hook an analog pedal set up to the yoke off the x-axis.
X2 - Don't you mean connected to the y-axis (vertical)?
+1 on the switch idea.
mytymaus007
« Reply #3 on: July 10, 2012, 08:54:33 pm »
so i should get a return to center shifter with button or a 4 speed shifter
