Author Topic: Magnetic shield for speakers?  (Read 2262 times)
IronBuddha
  • Last login:May 04, 2018, 11:36:27 pm
« on: July 09, 2012, 12:15:12 pm »
The monitor on my mame cabinet has the purplish coloring on the top because the speakers are a few inches in front of it. Is there some sort of magnetic shield wrapping or anything I can do to stop this? In case if it might help it's a 21in Sony computer crt monitor.
ed12
Re: Magnetic shield for speakers?
« Reply #1 on: July 09, 2012, 01:19:25 pm »
hi
a piece of light tin will do just fine
what u need to sheild is the mag
so u can cut a piece that will mount and cover the mag and u should be fine
no need to ground
ed
  • Last login:February 14, 2026, 11:45:41 am
« Reply #2 on: July 11, 2012, 05:50:05 pm »
head on over to the dollar store and find some metal (magnetic) cups/bowls what have you, and just stick them like a cover over the magnets on the back. if you can't find one the right size that the magnet will keep on by itself, just use a dab of hot glue or something. just as long as the magnet is covered, the metal will keep the field down.
portugese pirate
  • Last login:March 06, 2025, 06:07:58 pm
« Reply #3 on: August 29, 2012, 06:53:19 pm »
the wifes cookie sheets work well..................lol
Mysterioii
« Reply #4 on: August 30, 2012, 01:13:59 pm »
If the above suggestions don't work well enough for you, consider something like:
http://www.goldmine-elec-products.com/prodinfo.asp?number=G18646
