Author Topic: Crazy Taxi Sitdown Stick Shifter  (Read 1410 times)
d7onr8
  • Last login:August 31, 2020, 10:18:42 pm
« on: June 28, 2012, 08:56:03 pm »
I just got a Crazy Taxi Sitdown but the shifter feels loose.  The weight of the shifter causes it to slump down and activate Reverse.  For the time being, I mounted the assembly upside down so that it will hit Drive instead.  I took out the shifter assembly and both microswitches for Drive and Reverse work fine.  Inside the unit, everything seems in tact but is there supposed to be a spring or something that keeps it in the upwards Drive position?  Also, is it supposed to hover in the neutral position?  Thanks in advance.
d7onr8
Re: Crazy Taxi Sitdown Stick Shifter
« Reply #1 on: June 29, 2012, 12:41:41 pm »
Fixed it.  I checked Happs site and one of the exploded diagrams showed a spring is supposed to be located in the shaft that puts tension on the plastic nub at the end.  So I grabbed one from a pen and got it working.
Anybody know a source for NOS, repro stickers or spare parts?
Well Fed Games
  • Last login:Today at 10:45:41 am
  • Delicious!
« Reply #2 on: June 29, 2012, 01:06:40 pm »
I've looked a bit myself, and not found a source, and spares seem really expensive overall (it is the driving cab I would most love to build/own, so I keep an eye out).
