Author Topic: My (new) Makvision just went black!  (Read 3954 times)
dekar24k
  • Last login:April 28, 2019, 03:50:11 pm
    • ArcadeForum.com
« on: June 24, 2012, 10:24:31 am »
Ok, so I bought a new 29" (27") tri-mode Makvision/Wei-Ya monitor from Xgaming last year and I have been using it in my cab ever since. Although it has worked "ok" I have still had a few issues with it, one being that some resolutions are a bit "shaky". So today I disconnected the degauss coil (cable) as I thought the shaking was degauss-related, but when I turned my cab on again the monitor is all black. I can "hear" that it's turning on, but there is absolutely no picture.
I tried reconnecting the degauss cable and still no picture. HELP!
Any advice on what to do?
Dang .. I wish I still had my WG D9800 .. :(
Finished project: "The Saloon Arcade" - 2 player upright cabinet
Joystick.net - Retro gaming news and reviews
grantspain
Re: My (new) Makvision just went black!
« Reply #1 on: June 24, 2012, 10:35:59 am »
do you have a glow from the tube heaters?
if you turn up screen volts do you get a raster?
dekar24k
    • ArcadeForum.com
« Reply #2 on: June 24, 2012, 10:41:35 am »
No, there is no glow from the tube heaters. Also, I'm not sure how to turn up screen volts?
grantspain
« Reply #3 on: June 24, 2012, 05:45:21 pm »
screen volts is next to focus on the flyback transformer-check if you have static on the screen also
dekar24k
    • ArcadeForum.com
« Reply #4 on: June 25, 2012, 02:07:00 am »
Thanks, will try that now and report back. :)
RejectedManiac
  • Last login:January 07, 2019, 08:27:01 pm
« Reply #5 on: July 09, 2012, 09:04:17 am »
No neck glow means no high voltage. I would also check to see if the flyback went bad. You never know.
MonMotha
« Reply #6 on: July 09, 2012, 03:07:34 pm »
Keep in mind that a lot of these modern digital monitors have HV supply that's not driven by the horizontal output and do not derive their heater voltage from the flyback at all.  Obviously, you aren't going to get a picture with no heater, but "no heater == no HV" is not a particularly valid assumption on these monitors.
dekar24k
    • ArcadeForum.com
« Reply #7 on: July 09, 2012, 03:20:23 pm »
What is weird that this happened when I connected and disconnected the degauss cable. It worked perfectly before I did that.. Maybe it's related?
  • Last login:January 26, 2026, 07:56:08 pm
« Reply #8 on: July 11, 2012, 02:40:20 am »
some of these monitors have a ground stud near the degauss plug. You haven't accidentally plugged a ground into the degauss plug have you? (i've done it.)
check your fuses and make sure you didn't blow anything.
is this the M3129?
dekar24k
    • ArcadeForum.com
« Reply #9 on: July 20, 2012, 03:54:51 am »
is this the M3129?
Nope, didn't pull any other plugs. I will check the fuses thanks!
BTW, I haven't had time to look at this issue in a while, but I turned my cab on yesterday just for fun and suddenly the monitor had picture again. But the picture was all washed out, bright and blinking. It looked totally messed up.
I uploaded a video of it here:
Has anyone seen anything like this and can tell me what's wrong?
« Reply #10 on: July 21, 2012, 09:11:47 pm »
get a reading on the B+ while it's on and running. is it varying in conjunction with the screen goofyness?
dekar24k
    • ArcadeForum.com
« Reply #11 on: September 01, 2012, 03:09:15 pm »
Ok, I'm a total noob. I don't know where the B+ is and I don't even have a voltage meter to read it. :)
Anyways, I have tried unplugging and re-plugging the degauss coil. I haven't tried anything else because I am certain that I haven't touched any of the pots.
Should I just get a new chassis/motherboard? Having another CRT monitor of this size shipped to Norway will cost me no less than $1k .. :(
