Author Topic: can you use this controller with mixwaver 2  (Read 3143 times)
Shieldwolf
  • Last login:November 16, 2020, 12:48:53 am
  • SpearShield.com
« on: October 03, 2003, 11:51:50 pm »
i was looking at the beatmania dj controls and I thought it would be cool to use with mixwaver? Any Ideas on if it would work. I do have the ps2 to usb adapter, but I hate to blow 45-100 dollars on something i can't use
hooded_paladin
  • Last login:November 06, 2013, 08:59:01 pm
  • Finch! hahaha
Re:can you use this controller with mixwaver 2
« Reply #1 on: October 04, 2003, 10:00:18 pm »
it works all right.  Especially because mixwaver lets you set two buttons as the turntable (on for each direction, when you play on an actual controller)  (actually, I've only hone that with MixWaver 1.  I think it'd be the same with MixWaver 2)
7 key:
The Konami regular iidx controller (you can get one for about $100) and the Arcade-Style (about $600 because there are very limited quantities) work very well (not like Soft-pads for DDR  :P )
do NOT get the double-triangle-shaped controller with small round buttons from RedOctane.  They just aren't acceptable.
5 key:
although I don't really follow these, from what I know the DJ station pro is the only acceptable one.  You're also well off playing 5-key on the 7 key controller, because it does work (there's just an extra 2 keys between the keys and the turntable)
I just ordered a normal konami beatmania iidx controller from someone for $100 (that includes shipping)  It should be here soon.  Although I'm aiming towards a modded PS2 and official beatmania games, I'll play mixwaver till I get enough money.
There is SO a spoon.
