Author Topic: Question about Hyperspin and U360  (Read 1684 times)
jammin0
« on: June 18, 2012, 05:13:55 pm »
S, I have my system up and running great.  Instead of using an encoder for my controls I am just connected using the u360 and it's 8+shift buttons.  Everything works great and I have plenty of buttons but I am running into a hitch with some emulators other than MAME.  It seems as though you must hit the escape key in order to exit the emulator.  Is there an easy way to have the u360 emulate an esc key press or am I screwed without some kind of encoder?
Anyone else run into this same problem.
Uncle Monkey
  • Last login:September 12, 2020, 10:16:25 pm
  • P24L
    • Project Thread
Re: Question about Hyperspin and U360
« Reply #1 on: June 19, 2012, 09:55:16 am »
you can use xpadder or joy2key to map your gamepad buttons to be key presses. that's your best bet. either assign all your buttons to key presses, or just one to the esc key.
« Reply #2 on: June 19, 2012, 10:25:59 am »
jammin0
« Reply #3 on: June 19, 2012, 10:25:26 pm »
Thanks dudes, that's just what I needed.
