Author Topic: how to play Mame  (Read 3520 times)
troy10
  • Last login:July 16, 2012, 05:56:40 am
how to play Mame
« on: June 12, 2012, 10:51:20 pm »
Have downloaded Mame And Galaga And 1942 the main screens load unsure how to load credits or play game on computer keyboard help needed please to get me started
DaveMMR
Re: how to play Mame
« Reply #1 on: June 12, 2012, 10:54:28 pm »
http://www.mameworld.info/
Read through that for everything you need.  You insert coins with 5 and 6 and start with 1 and 2. You can change settings by hitting TAB.
troy10
« Reply #2 on: June 12, 2012, 11:02:24 pm »
Thankyou Tried using the options shown all that i can get to work is tab key brings up a list of options that i can scroll thru but not access bit more help needed please
  • Last login:Today at 01:53:38 am
« Reply #3 on: June 12, 2012, 11:26:27 pm »
Enter selects the highlighted option/enters the submenu.
Esc takes you up a menu level or exits the menus or MAME.
Input (This Game) menu lists the keys mapped to the functions.  To change the key, highlight the function, press enter, then press the desired key/button.  If you mess up, press enter, then press escape (shows "none"), then enter, then escape. (restores that function to default)
Description  | Key
P1 Coin      | 5
P1 Start     | 1
P1 Right     | <Right Arrow>
P1 Left      | <Left Arrow>
P1 Up        | <Up Arrow>
P1 Down      | <Down Arrow>
P1 Button 1  | <L-Ctrl>
P1 Button 2  | <L-Alt>
P1 Button 3  | <Space>
P1 Button 4  | <L-Shift>
P1 Button 5  | Z
P1 Button 6  | X
Cancel       | <Esc>
Select       | <Enter>
Config       | <Tab>
Pause        | P
« Last Edit: June 12, 2012, 11:31:38 pm by PL1 »
paigeoliver
  • Awesome face!
« Reply #4 on: June 12, 2012, 11:40:43 pm »
« Reply #5 on: June 12, 2012, 11:43:22 pm »
troy10
« Reply #6 on: June 13, 2012, 01:11:36 am »
thanks for help thus far can some one explain what p1 p2 etc is what buttons do i push at the moment every time i open a game i must reconfigure in input tab
DaveMMR
« Reply #7 on: June 13, 2012, 06:34:16 am »
Settings should save upon exit of game if you change them.  If they don't save, make sure your folders aren't "read only".
And here's the link I meant last night - http://mamedev.org/devwiki/index.php?title=Frequently_Asked_Questions. This has everything you will need.  Here's an example:
The arrow keys work, but I can't fire, jump, etc.
Here are the default controller buttons for many games:
5 - Insert Coin
1 - Start
Arrows - Move
Ctrl - Action Button 1
Alt - Action Button 2
Space - Action Button 3
Mouse - Analog Control (needed for some games)
P - Pause
ESC - Quit MAME
F2 - Service Mode
Tab - MAME Options Menu
Note: There are many games with much more complex controls. If you need to see or change a games controls, press Tab and choose "Input: This Game".
« Last Edit: June 13, 2012, 06:40:43 am by DaveMMR »
troy10
« Reply #8 on: June 13, 2012, 06:42:08 am »
Thanks Dave been on it all day the joys of being a newbie lots of info to decipher
I am am now hunting down a controller i am going to try and build a cabnet this month
TopJimmyCooks
« Reply #9 on: June 13, 2012, 08:45:07 am »
Here, this should help.
http://lmgtfy.com/?q=how+to+use+mame
 :cheers:  Well played, sir.
Let me move with all due alacrity to post in agreement and support of Mr. Scott's assessment. Indeed, well played, Mr. Oliver.
I'll be on the lookout for my next opportunity to swoop in and use that bad boy!
