Author Topic: Power to monitor board  (Read 1170 times)
oldmumak
  • Last login:July 19, 2012, 09:33:18 pm
« on: June 12, 2012, 07:43:40 pm »
I'm not getting any video when I turn on my arcade. The black and white wires in the pics are coming from a fuse and the isolation transformer, and are going into the monitor board. On the connector shouldn't the black wires match up?
MonMotha
Re: Power to monitor board
« Reply #1 on: June 12, 2012, 09:15:56 pm »
Heh, yup.  They should.
The pinouts for those connectors aren't fully standard.  The "normal" pinout when using a 3 position connector like that has earth ground in the middle, but apparently somebody decided to be different when wiring up either your monitor or cabinet.  Moving them to match up should fix your problem.
