March 05, 2026, 05:23:03 pm
Home
Help
Search
Login
Register
News:
Support this site
Shop
Amazon Arcade Stuff
through our link. Thank you!
Main
Monitor/Video Forum
Will a 33” Wells Gardner D9200 Chassis work on a 27” Wells Gardner D9200 Tube?
Main
Restorations
Software
Audio/Jukebox/MP3
Everything Else
Buy/Sell/Trade
Project Announcements
Monitor/Video
GroovyMAME
Merit/JVL Touchscreen
Meet Up
Retail Vendors
Driving & Racing
Woodworking
Software Support Forums
Consoles
Project Arcade
Reviews
Automated Projects
Artwork
Frontend Support Forums
Pinball
Forum Discussion
Old Boards
Raspberry Pi & Dev Board
controls.dat
Linux
Miscellaneous Arcade
Wiki Discussion
Old Archives
Lightguns
Arcade1Up
Try the site in https mode
Site News
Unread posts
New Replies
Recent posts
Rules
Chatroom
Wiki
File Repository
RSS
Submit news
« previous
next »
Send this topic
Print
Pages: [
1
Go Down
Author
Topic: Will a 33” Wells Gardner D9200 Chassis work on a 27” Wells Gardner D9200 Tube? (Read 3304 times)
dgame
Trade Count:
0
Full Member
Offline
Last login:June 01, 2025, 11:09:55 pm
I am no Jedi
on:
June 06, 2012, 04:53:24 pm »
Would a chassis (deflection board, neck board, remote control board,VGA interface board, etc.) from a 33” Wells Gardner D9200 work on a 27” Wells Gardner D9200 Tube?
Logged
lilshawn
Trade Count:
+3
Full Member
Offline
Last login:March 01, 2026, 06:22:50 pm
I break stuff...then fix it...sometimes
Re: Will a 33” Wells Gardner D9200 Chassis work on a 27” Wells Gardner D9200 Tube?
Reply #1 on:
June 06, 2012, 07:52:27 pm »
Technically....yes. but no.
you would basically need to change this stuff...
theoretically, if you add/remove/change as needed... these items, it should work.
Last Edit: June 06, 2012, 07:54:38 pm by lilshawn
Logged
ed12
Trade Count:
0
Full Member
Offline
Last login:March 31, 2018, 03:44:39 pm
it is what it is..."Nobody Said It Was Easy"....
Reply #2 on:
June 06, 2012, 09:40:09 pm »
let alone the fact it may or may not be a bonded yoke
ed
Logged
Shipping something from the U.S. to Canada for repair/exchange? Please use USPS to avoid (additional?/excessive?) shipping charges. PM me if you have any questions.
dgame
Trade Count:
0
Full Member
Offline
I am no Jedi
Reply #3 on:
June 07, 2012, 11:17:46 am »
Thanks,
Looking at what lilshawn posted It seems that only the neck boards are the same part.
The Deflection and Input boards have different part numbers.
Everything should hook up though.
So what do you all think would happen if I hooked the good 33" Deflection and Input boards to the 27" neck board?
Logged
ed12
Trade Count:
0
Full Member
Offline
Reply #4 on:
June 07, 2012, 12:45:20 pm »
well alot in short order
it should fire up
but here is the rub
the yoke used on the 27" chassic is differnet then the used on the 33" tube
there is a small white tag on both of the yoke's
read there #'s and u will c this fact
and now this is what will happen
with the yoke's benning different it is a impedance problem
and the hot circuit is tuned to the yoke
u will run the risk of blowning up your hot transistor as a min problem
in short u are asking for problem's..but hey to each there own
ed
Logged
dgame
Trade Count:
0
Full Member
Offline
I am no Jedi
Reply #5 on:
June 07, 2012, 06:47:15 pm »
Thanks ed12,
I'm looking for someone to service the 27" chassis.
I sent out inquiries to some repair people online.
Any suggestions?
If I cant get it repaired I guess I'll have to order a new Makvision or something.
I had planned for that possibility.
Logged
Send this topic
Print
Pages: [
1
Go Up
« previous
next »
Main
Monitor/Video Forum
