Author Topic: MalaFE turning XP wav volume down  (Read 2837 times)
CoryBee
  • Bopity Boopy
« on: June 06, 2012, 02:55:37 pm »
I looked all over to fix this but to no avail.
Every time I start MalaFE, my wav volume slider gets set to half full (or half empty if your that kind of person).
This is really annoying. I have to manually go into Mala sound config every time I want to return the volume to normal. Then when I restart the arcade it goes back to half volume.
Any help is much appreciated.
  • Last login:December 19, 2025, 12:23:29 pm
Re: MalaFE turning XP wav volume down
« Reply #1 on: June 06, 2012, 03:38:40 pm »
Longshot, but I had some weird other issue where settings weren't being saved and it was that MALA was shutting the computer down instead of me shutting it down myself.  Exited MALA and shut down.  The settings stayed.  I can't even remember what the issue was now.  ???
CoryBee
  • Bopity Boopy
« Reply #2 on: June 07, 2012, 08:19:23 am »
I have tried all kinds of things. Shut it down properly too, through the menu. The only way I was able to almost fix this was to set the joystick up down to turn the MALA volume up in the background which turns the WAV slider up on the sound controls too.......crappy way to do this.
« Reply #3 on: June 27, 2012, 11:17:42 pm »
disable fades, or try the beta.
Raffles
  • Last login:January 25, 2013, 04:55:20 pm
« Reply #4 on: July 29, 2012, 06:12:52 am »
I had a similar problem - upgrading to v1.745 (beta) fixed it for me.
