Author Topic: Misfire Arcade 90%  (Read 7407 times)
crumptinite
  • Last login:September 06, 2017, 01:35:19 pm
Misfire Arcade 90%
« on: June 01, 2012, 07:38:18 am »
Going for a taito with a few changes. Started a while back will post progress.
This will not be a dedicated cabinet. There will be a drawer in which i put a laptop in and plug everything up to whenever I want to play.
Materials:
2x of 16mm 4x8 MDF
4 caster wheels
2x 2x4
1 can primer oil based
1 can black paint (oil based)
2x HAPP Comp.
Lots of buttons
21in Dell ScreInfluenced by the taito rama
« Last Edit: June 22, 2012, 01:14:09 pm by crumptinite »
crumptinite
Re: Taito cabinet 20%
« Reply #1 on: June 01, 2012, 08:17:25 am »
First Cuts
String Method Not perfect but it worked well enough
Both sides cut a little water damage from the ride home but its the bottom so no biggy.
More updates to come
« Last Edit: June 01, 2012, 08:34:53 am by crumptinite »
crumptinite
« Reply #2 on: June 03, 2012, 02:14:31 pm »
So I've hit a wall pretty early. The problem is MDF splitting. I made little strips of extra MDF to connect the cabinet together. I even drill a small hole first but the woo keeps splitting. Any advice.
Acids
  • Last login:July 26, 2025, 06:10:07 am
  • Bring It.. Smart arse!
« Reply #3 on: June 03, 2012, 11:32:17 pm »
wanna post a pic,  then we can help better.
Im guessing some battons will help though?
GregD
  • Last login:December 23, 2025, 04:38:08 pm
    • Arcade Nebula
« Reply #4 on: June 04, 2012, 02:05:17 pm »
MDF should not be screwed into from the ends.  It just always splits or mushrooms because the material is so dense.  I would get some softwood and use that to make batons.  This is a much better method for assembling an MDF cabinet.  Personally, I really hate MDF but it seems to be what everyone around here uses.  Good luck!
crumptinite
« Reply #5 on: June 04, 2012, 02:45:37 pm »
thanks for the responses but I think I got the fix. Wood glue!! So I glued and let settle it's holding like a champ. I think i'll throw some different material connectors ( prolly cutup 2x4) in when I attatch the back, cp, and monitor mount. Will post picks when I get back.
crumptinite
« Reply #6 on: June 04, 2012, 10:12:45 pm »
Took it over a friends house who has every tool imaginable and got some progress...
Glued and Screwed main portions letting it sit and dry till tomorrow
crumptinite
Re: Taito cabinet 35%
« Reply #7 on: June 10, 2012, 09:22:39 am »
Lot of progress made. Its finally standing
Control panel drilled . Don't mind the colors. Continuous hinge used underneath
Door, laptop mount, and speaker holes are all thats left besides painting. Anyone got any advice on attaching the marquee?
  • Last login:Today at 05:00:38 am
« Reply #8 on: June 10, 2012, 09:44:51 am »
Here's a recent thread with a number of options to consider.
http://forum.arcadecontrols.com/index.php?topic=119998.0
crumptinite
Re: Taito cabinet 55%
« Reply #9 on: June 11, 2012, 10:43:07 am »
So those are pretty much retainers that i screw into the cabinet? Do they have enough room for plexi?
« Reply #10 on: June 11, 2012, 03:22:13 pm »
Yes, the retainers screw into the cabinet.
Do they have enough room? -- Which retainer and what thickness plexi?   :dunno
crumptinite
« Reply #11 on: June 14, 2012, 12:56:27 am »
So I started on the cp and marquee. Any comments on the WIP? Blue lines are just my guide lines.
crumptinite
« Reply #12 on: June 15, 2012, 09:56:50 pm »
Couple pics
Starting with primer on cp
More to come
crumptinite
« Reply #13 on: June 21, 2012, 02:46:31 pm »
View after 2 coats
Sanded two 1 more coat
Sanded again and last coat. A few imperfection but hopefully 1500 grain paper and lacquer will fix it.
Letting that paint dry, started wiring the cp.
Vidiot
  • John 3:16
Re: Misfire Arcade 75%
« Reply #14 on: June 22, 2012, 08:31:00 am »
I love the classic Taito shape. Looks like its coming together nicely. I'm curious though....so the only thing holding your cab together is wood glue? I mean it looks like you didn't use any batons at all. I'm not sure I've ever seen that before.
crumptinite
« Reply #15 on: June 22, 2012, 09:26:53 am »
Didn't make an up date of that change. There are small screws that were drilled into the ends of the MDF. The wood glue alone was  not strong enough. didnt use batons because it wasn't necessary. I'm going to redo the thread with more details when it's done.
crumptinite
« Reply #16 on: June 22, 2012, 09:40:40 am »
So pretty much done besides throwing on same graphics.
Here is the laptop drawer better pics coming.
« Reply #17 on: June 22, 2012, 11:05:37 am »
I'd re-enforce with some L brackets and the like.   love the shape, very Taito-ish
are the green buttons for coin up? I know it sounds silly, but I'd keep them uniform, like green to the left and start to the right for both P1 and P2, its an aesthetics thing, symmetry doesnt always look better. Id go all red buttons for the players too, break up all that black and white a little and play off the color of the dynamite sticks.
crumptinite
« Reply #18 on: June 22, 2012, 12:30:29 pm »
Buttons are only temporary for wiring so dont mind the colors. Gonna be white on one side and black on the other. Each with a single red button. Itll make sense when i finally post my control panel artwork. As of right now there is no art on it but ot will all come together
crumptinite
« Reply #19 on: June 22, 2012, 12:34:01 pm »
As for l brackets... I kinda stayed away because i just never do projects with them. Its pretty solid... Even attempted to pull it apart... I sat on the inside of the cabinet with not so much as a creek coming from it
Re: Misfire Arcade 90%
« Reply #20 on: June 22, 2012, 02:00:03 pm »
your call, I'd rather drop $8 for peace of mind :)
I was thinking, since you havent finalized art and what not, you could mismatch the buttons, white buttons with black rings on a white background on one side, black buttons with white rings on a black background on the other side, just looks good in my head.
crumptinite
« Reply #21 on: June 22, 2012, 02:25:13 pm »
Well made a trip to lowes and they were going for more than i wanted to pay.
You almost just revealed my theme. Its almost exactly like u described
« Reply #22 on: June 22, 2012, 03:13:21 pm »
great minds ;)  :cheers:
crumptinite
« Reply #23 on: June 26, 2012, 12:28:25 pm »
Small update:
Marquee printed and installed. Printed at local shop. Mounted with clear plastic corner protecters from home depot. No screws required and easy to remove
Last of the playable buttons finally arrived only 1 button to change minus vinyl and cp art
