Author Topic: Mamewah Help  (Read 2762 times)
Joelteon
  • Last login:June 04, 2012, 03:39:15 pm
Mamewah Help
« on: May 31, 2012, 05:56:45 pm »
note to admin: sorry if this is in the wrong thread, i couldnt find mamewah stuff under the support section?
Im looking to use a frontend for building an arcade. Originally, i was using Puppy Arcade, but im not particularly experienced with linux and couldnt get it to really work for me. Then i heard about MameWah, and it seemed to be the solution to what i was looking for; namely a frontend where i dont have to use pc-like interface (ie mouse/keyboard) to navigate to the emulators etc.
It wasnt till i went to post my MameWah error report that i noticed on this site that there are other options for frontends, so i will keep an open mind to those.
HOWEVER. i was really attracted to the apparent customization options MameWah supports, in particular designing menus through photoshop. When i tried to set mamewah up per this youtube video:
it crashed the heck out of my computer; my desktop background changes to a black screen, my resolution resorts to native and i basically cant get it back to normal without unplugging my computer.
I updated all the drivers or w.e, my direct X is up to date, so i have no idea what could be causing it.
This is the error report:
5/25/2012 5:56:47 PM MAMEWAH v1.65 launched
5/25/2012 5:56:47 PM Cursor scheme: Windows Aero, Arrow: %SystemRoot%\cursors\aero_arrow.cur, Wait: %SystemRoot%\cursors\aero_busy.ani, AppStarting: %SystemRoot%\cursors\aero_working.ani
5/25/2012 5:56:47 PM Desktop colour: 0
5/25/2012 5:56:47 PM Wallpaper filename: C:\Users\Joel\AppData\Roaming\Microsoft\Windows\Themes\TranscodedWallpaper.jpg
5/25/2012 5:56:48 PM Desktop display mode: 1680x1050 @ 59Hz, 32bit colour
5/25/2012 5:56:48 PM Decimal symbol: '.'
5/25/2012 5:56:48 PM Games list read: mame-0.lst
5/25/2012 5:56:54 PM Mode 640 x 480 @ 60Hz, 16bit colour selected after 2 attempt(s) at 1/2 second intervals.
5/25/2012 5:56:54 PM Layout selected: F:\OPERATION FISCAL JACKHAMMER\Mamewah\config\layout.lay
5/25/2012 5:57:01 PM Error: 429 ActiveX component can't create object in CTRLR_InitialiseDI
5/25/2012 5:57:01 PM Error: 429 ActiveX component can't create object in SFX_InitialiseDS
5/25/2012 5:57:02 PM Error: 429 ActiveX component can't create object in SFX_InitialiseDS
5/25/2012 5:57:03 PM Error: 429 ActiveX component can't create object in SFX_InitialiseDS
5/25/2012 5:57:04 PM Error: 429 ActiveX component can't create object in SFX_InitialiseDS
5/25/2012 5:57:05 PM Error: 429 ActiveX component can't create object in SFX_InitialiseDS
5/25/2012 5:57:06 PM Error: 429 ActiveX component can't create object in SFX_InitialiseDS
5/25/2012 5:57:07 PM Error: 429 ActiveX component can't create object in SFX_InitialiseDS
5/25/2012 5:57:08 PM Error: 429 ActiveX component can't create object in SFX_InitialiseDS
Any help would be welcome, and if there is another frontend available that offers similar customization options such as photoshopping my own menus, if would be open to recommendations there as well!
tony.silveira
  • Last login:September 27, 2024, 03:04:35 pm
    • my baby
Re: Mamewah Help
« Reply #1 on: June 01, 2012, 09:00:05 pm »
did you install the mamewah support files?
gonzo90017
Re: Mamewah Help
« Reply #2 on: June 02, 2012, 02:20:21 am »
Have you installed the sound and video card drivers?
Joelteon
Re: Mamewah Help
« Reply #3 on: June 03, 2012, 07:49:12 pm »
yup i went through all the support files. Most of them it said i even had a more recent version too
gonzo90017
Re: Mamewah Help
« Reply #4 on: June 05, 2012, 02:23:00 pm »
Does your monitor even support 640x480?
