Author Topic: P22N10L replacement?  (Read 3216 times)
  • Last login:January 26, 2026, 07:56:08 pm
« on: May 30, 2012, 04:37:55 pm »
what's a good replacement for a P22N10L coil driver trasistor?
Ive tried IRL540N's that iv'e ordered from great plains electronics and sometimes they work fine, other times they work a few times (6-10 and then go open) sometimes I don't even get once, they just smoke up as soon as power is applied to them.
I'm not buying cheap Chinese ebay crap or anything...course i don't know where they are getting them from...but i'm not having great luck with them.
EDIT: fat fingers and making spleling misteaks
« Last Edit: May 30, 2012, 04:40:19 pm by lilshawn »
ed12
Re: P22N10L replacement?
« Reply #1 on: May 30, 2012, 09:22:38 pm »
hi
i ran a cross ref
look's like irf make's a good 1
it can handle 2-x the power
on res is 0.064 which make's it .016 under your's
or u could use the intersil
RFP22N10
ed
« Reply #2 on: May 31, 2012, 11:59:43 am »
Ya I pretty much found the same thing...They should be more than ample.
Well, maybe I just got a bad batch of transistors. I'll try these ones again next one that breaks, if I still have issues with them, I'll call up GPE.
Ken Layton
  • Guru
  • Technician
« Reply #3 on: June 06, 2012, 02:35:07 am »
When you replace the mosfet transistor, be sure to also replace the diode on the coil being driven by that transistor.
« Reply #4 on: June 06, 2012, 09:38:34 am »
yeah I do that for sure...it's a 2 cent part so I do it anyways irrespective if it's still good or not.
