Author Topic: Hinges for CP door! Advice needed!  (Read 1678 times)
RedSquirrel
  • Last login:September 18, 2003, 12:07:55 pm
« on: October 01, 2003, 02:47:27 pm »
What is the best hinge I could use for the door of my cp  ???
I bought an expensive (well $7/
1UP
  • Token Junkie
    • 1UPArcade
Re:Hinges for CP door! Advice needed!
« Reply #1 on: October 01, 2003, 03:30:24 pm »
I used the type you first described (the hidden hardware ones with a round base that you make a hole for in the door)
Well, these work better if you set the round part into the side of your cab, rather than the door.  You might also need to bevel the inside edge of your door so it doesn't scrape when you open/close.
I'll try to post pictures of my installation when I get time.  You might also consider piano hinges (continuous hinges).
My other job...
RedSquirrel
« Reply #2 on: October 01, 2003, 03:46:49 pm »
thanks for the reply. I will look into putting that bit inside the cab, not sure if will solve the prob i have with it though.
Take a look at these pics.
With hinge (side view, sorry)
Without (and the way i want it to be)
tmasman
  • Last login:January 04, 2024, 03:50:44 pm
  • Hello...
    • My (no so up to date) Home
« Reply #3 on: October 01, 2003, 03:59:23 pm »
Shouldn't it work with the hinge installed backwards?
Route out the area for the hinge in the side wall instead of the door...
It seems like that should work. The 2 pieces of wood are placed in the same orietation to each other except that they are swapped.
Give it a shot! (Or let me/us know why that wouldn't work)
~ tmasman
I'm not a freak!...
Oh wait...
Yes I am...
RedSquirrel
« Reply #4 on: October 01, 2003, 06:04:19 pm »
~ tmasman
Ill give it a shot! Just a pain in the ass, cos i have to route out the hole manually (with a hammer and chisle) although it probably didnt take more than 30 mins to do the one in the door.
soslo
  • Last login:March 10, 2012, 03:23:36 pm
  • The Governator
    • My website does not have a name yet
« Reply #5 on: October 17, 2003, 02:40:56 pm »
any pics yet 1up?
5 MAME cabs and counting...
Ever wonder what full side art looks like?
http://www.aaronmurray.com
RedSquirrel
« Reply #6 on: October 17, 2003, 06:52:45 pm »
heh my old thread.
Hopefully have pics up soon in the annoucement area, its very nearly finished  ;D
