Author Topic: mala/mame  (Read 4136 times)
br2000ad
  • Last login:March 22, 2013, 03:55:09 am
mala/mame
« on: May 03, 2012, 09:29:35 am »
is there a way to go straight into game without using joystick
left/right and pressing select not being lazy its just don,t have to on m2 and cps3
just liked to know if theres a way
TopJimmyCooks
Re: mala/mame
« Reply #1 on: May 03, 2012, 10:45:29 am »
you can set a game to start on mala start in the option tabs.  not sure where but I've seen it.
br2000ad
Re: mala/mame
« Reply #2 on: May 03, 2012, 12:04:24 pm »
i,ll try and find it...let u know
br2000ad
Re: mala/mame
« Reply #3 on: May 03, 2012, 12:45:25 pm »
found it but dont load straight into game you still
have to move joystick left/right etc
TopJimmyCooks
Re: mala/mame
« Reply #4 on: May 03, 2012, 02:07:56 pm »
joystick left right is part of Mame rather than Mala- usually referred to as the "nag screen."  search on "mkchamp diff" and get info on compiling your mame exe to eliminate that.
MTPPC
Re: mala/mame
« Reply #5 on: May 03, 2012, 02:26:02 pm »
With mame 1.43, there are config settings to not display the nag screens, but if your game reports a problem, you can't get rid of that notification. Otherwise, the nag only happens the first time you run the game.
http://pinballmd.com/
br2000ad
Re: mala/mame
« Reply #6 on: May 04, 2012, 03:20:44 am »
i,ll try that one later cheers
do all versions of mame work with mala..?btw
br2000ad
Re: mala/mame
« Reply #7 on: May 04, 2012, 07:03:37 am »
i,am using version 0.103..
tryed in options,default game option then miscellaneous=there was
a skip game info so tryed that and does work on some game but not all
will give 0.143 a try a bit later
br2000ad
Re: mala/mame
« Reply #8 on: May 04, 2012, 07:39:41 am »
tryed 1.43 version can,t find nag screens...?
