Author Topic: PUSH BUTTON LED POWER!!  (Read 2860 times)
premier
  • Last login:October 10, 2020, 02:11:31 am
« on: May 03, 2012, 04:03:51 am »
Hi Guys,
Have a few questions regarding the illumination of some push button leds.
Hoping somebody can shed some light on the matter.
Looking to illuminate 17 push button leds in my MAME cabinet.
I want these to be permanently lit and I want to use a pc power supply to do the job. I will be slicing a Molex 8981 using wires red (+5v) and black (-).
The buttons at hand are Ultimarcs "Ultralux" translucent push buttons - see link - which have a 5V led built in.
I have read some contradicting info regarding the illumination of multiple LEDS from one power source - and am a little confused.
Basically I would like to know the following:
1.
Are resistors required? - Ultimarc quotes the following on their website: If you simply want to light the buttons permanently, just connect to a 5 volt supply, such as from a PC hard drive power connector. Using our pre-made "daisy-chain" harness will save a lot of time.
Is this the case? I cant seem to see anything that resembles a resistor built into the led holder. Written on the LED is: JA 5V DC
2. How should i wire all 17 up? Series or parallel?
According to http://led.linear1.org/led.wiz -
entering the following information
Source voltage: 5V
diode forward voltage: 5V (a guess? this is what is written on each led)
diode forward current (mA): 20 (a guess?)
number of LEDs in your array: 17
returns this result:
parallel connected with 100 ohm resistors on each led.
but entering this info
Source voltage: 5V
diode forward voltage: 3.3V (a guess? - but as recommended by the site)
parallel connected with 1 ohm resistors on each led.
SO...
do I use no resistors? 1 ohm resistors? or 100 ohm resistors? or other?
can anybody shed light onto this!?
thanks in advance!
« Last Edit: May 03, 2012, 04:07:44 am by premier »
matsadona
Re: PUSH BUTTON LED POWER!!
« Reply #1 on: May 03, 2012, 05:24:49 am »
1 : The Ultralux button LED lamps have a built in resistor so you don’t have to bother about that (or use that formulas). Just hook them up to any 5VDC source.
2: You connect all 17 LED lamps in parallel (in this case)
Regarding LED’s in general you always need a resistor in series to limit the current. And you should not have LED’s in parallel with just one resistor… you need one resistor for each parallel string of LED’s.
premier
« Reply #2 on: May 03, 2012, 08:52:16 am »
thank you kind sir  :D
that clears everything up for me
