Author Topic: Is this everything I need to start making a control panel?  (Read 1247 times)
ArcadeSeeker962
  • Last login:June 30, 2012, 09:58:05 am
  • Yes, a fighting snow man does exist!
« on: April 27, 2012, 11:03:55 pm »
I figuring out on paper everything I need for my control panel for the MAME cabinet that me and my father are building. I'm still a little bit new to this all, so correct me if I make any mistakes. I decided to take the no-soldering route, since that's what other members recommended. The control panel I chose is a 2-Player control panel.
Anyhow, I'm choosing GroovyGame Gear as my choice for buying the parts I need. Here's what I came up with:
2 Omni 4-way/8-way joysticks
12 Arcade Prime Pushbuttons
1 Player 1 Pushbutton
1 Player 2 Push button
1 Super High Trackball Install Kit
1 Trackball Mounting Kit
1 5v USB Power Cord(do I need more than one?)
Groovy TB 3'' Trackball
KeyWiz Max 2.0
I also remember reading from one of the other threads I posted that female crimp connectors are required, how many will I need of those? Also, what else do I need to make the control panel? If I wasn't suppost to post this, I apologize.
« Last Edit: April 28, 2012, 11:52:26 am by ArcadeSeeker962 »
GregD
  • Last login:December 19, 2024, 04:27:31 pm
    • Arcade Nebula
Re: Is this everything I need to start making a control panel?
« Reply #1 on: April 28, 2012, 10:00:08 am »
Do you have trackball already?  You have mounting kits on your list but no trackball.  You need a keyboard encoder as well.  Write down one Keywiz as well.  Anything else depends on your trackball.  Is it a usb trackball or do you need an optiwiz for it?
ArcadeSeeker962
« Reply #2 on: April 28, 2012, 11:51:49 am »
I do not own the trackball yet, but the trackball is going to be powered via USB through the control panel. Will this work  alright as a keyboard encoder recommendation, or is there a better keyboard encoder for MAME cabinet control panels out there?
http://www.amazon.com/American-Microsemiconductor-MM74C922N/dp/B001HFIXOC/ref=sr_1_3?ie=UTF8&qid=1335628413&sr=8-3
« Last Edit: April 28, 2012, 11:56:44 am by ArcadeSeeker962 »
