Author Topic: Quick List of Soft15khz Compatibile Video Cards  (Read 57890 times)
dskinchen
  • Last login:May 17, 2012, 04:02:05 pm
« on: April 26, 2012, 09:52:14 am »
Because I'm generally lazy and I couldn't find a quick list, I've started one using the posts from SailorSat's page. For full info and tweaks you still need to refer to the ArcadeInfo site. http://community.arcadeinfo.de/showthread.php?t=7925
If there are more cards that work, please add them or send them to me and I'll update the list.
ATI Radeon Mobile X200
ATI Radeon XPress 200 - "Gigabyte GA-8TRC410MNF-RH
Gigabyte Radeon X300
ATI Radeon X600 PCI-E (ASUS)
ATI Radeon X800 PCI-E (HIS)
ATI Radeon XPress 1250 - "ASUS M2A-VM|HDMI
ATI Radeon XPress 1250 - ASRock 4Core1333-FullHD
ATI Radeon X1650Pro PCI-E (Sapphire)
ATI Radeon X1650Pro AGP
ATI Radeon HD2400Pro PCI-E (Sapphire)
HIS Radeon 2900GT PCI-E
Gigabyte GA-MA78GM-S2H (AMD 780G / Radeon HD 3200)
ATI Radeon HD3450 PCI-E ATI Radeon HD3850
AGP ATI Radeon HD4350 PCI-E (ASUS)
ATI Radeon HD 4350 works with edid dongle
ATI Radeon HD4650 (Gigabyte HD4650 OC PCI-E - GV-R465OC-1GI)
ATI Radeon HD4670 PCI-E (GIGABYTE model GV-R467ZL-1GI)
Msi radeon 4850 hd 512 mb, gddr3
ATI Radeon HD4870 x2
ATI Radeon HD4850 PCI-E (Sapphire)
ATI Radeon 7000 AGP
ATI Radeon 7500 AGP
ATI Radeon 9200SE AGP - "MSI RX9200SE-T128
ATI Radeon 9200SE PCI - "Sapphire RADEON 9200SE Atlantis"
ATI Radeon 9250 AGP
ATI Radeon 9500 PRO AGP
Palit Radeon 9550
ATI Radeon 9600
ATI Radeon 9600 All-in-Wonder AGP
ATI Radeon 9600Pro AGP
ATI Radeon Mobility 9600 (HP nc6000)
ATI Radeon 9800 Pro AGP
NVidia GeForce FX5200 AGP
NVidia 6100 onboard - Abit NF-M2SV
NVidia GeForce 6150
NVidia GeForce 6600GT AGP
NVidia GeForce 7100 OnBoard
NVidia GeForce 7300GS PCI-E (Gainward Bliss 7300GS)
NVidia GeForce 7600GS AGP
NVidia GeForce 7600GT AGP
Nvidia GeForce 7950GX2 PCI-E (Leadtek)
Nvidia Geforce 8400 GS
NVidia GeForce 8400GS PCI-E works with edid dongle
Nvidia GeForce 8800GXT PCI-E (Leadtek) works with edid dongle
NVidia GeForce 9500GS PCI-E works with edid dongle
NVidia GeForce 9600GSO PCI-E 768MB DDR2 (EVGA) works with edid dongle
NVidia GeForce2 GTS AGP NVidia GeForce2 Pro AGP
NVidia GeForce4 MX 420 PCI
NVidia Riva TNT2 M64 AGP
NVidia Riva TNT2 AGP
NVidia Quadro4 NVS AGP
Matrox Millenium PCI
Matrox G100 AGP
Matrox P650 AGP
« Last Edit: April 26, 2012, 09:58:20 am by dskinchen »
notbillcosby
  • Last login:December 01, 2017, 01:54:48 pm
Re: Quick List of Soft15khz Compatibile Video Cards
« Reply #1 on: July 16, 2012, 03:14:23 pm »
I have the chance to pick up an ATI Radeon 9250 PCI card. I see the AGP version is in the list- does anyone have a reason to believe the PCI counterpart wouldn't work with Soft15khz?
Ian's BurgerBoss Cabinet project build thread!
http://forum.arcadecontrols.com/index.php/topic,129225.0.html
  • Last login:January 23, 2026, 06:10:10 am
« Reply #2 on: July 17, 2012, 08:27:49 am »
The PCI version of the 9250 should work perfectly.
Copacetic
  • Newbie
  • Last login:August 08, 2012, 04:02:47 pm
« Reply #3 on: July 31, 2012, 01:21:47 pm »
what would be the best/cheapest card to be able to use soft15khz and be able to play Street Fighter IV (obviously on a low resolution) ?
i just can't figure it out. thanks in advance.
Edit: PCI or PCI-E
segasonicfan
  • Last login:April 12, 2020, 02:34:26 am
« Reply #4 on: October 19, 2012, 07:05:32 pm »
Im trying to get it to work with a geforce 7800GT.  I install 15khz, reboot the machine and it looks exactly the same (regular VGA output).  Does that mean its just not compatible?  or is there a conflict in the driver?  I just downloaded the newest nvida driver for it and installed.
EDIT: found this: http://www.marcusnyberg.com/2011/01/17/soft15khz-and-problem-with-the-latest-nvidia-drivers/     I guess the newest drivers suck.  will try this when I get home and report back
« Last Edit: October 19, 2012, 07:14:59 pm by segasonicfan »
Dilomos
  • Newbie
  • Last login:April 28, 2013, 08:01:11 am
« Reply #5 on: October 20, 2012, 12:41:46 pm »
My Nvidia 7900GS work with forceware 163
segasonicfan
« Reply #6 on: October 21, 2012, 07:18:27 pm »
ah it works!  Geforce 7800 GT is a go with the old forceware drivers and a sync combiner:
http://www.epanorama.net/circuits/vga2rgbs.html
BLASTEROO
  • Last login:April 10, 2013, 12:30:21 am
  • Tomato, cheese, tuna and pinneaple...? For sure!!!
« Reply #7 on: December 17, 2012, 09:52:15 am »
Hi guys,
I used to have a radeon 9600 pro agp installed on a P4 and it work fine, but I was forced to move to PCI-E due to a mobo failure.
I'm trying to use a RADEON HD 2400PRO = asus eah 2400 pro
http://www.ebay.com/ctg/ASUS-ATI-Radeon-HD-2400PRO-EAH2400pro-HTP-256-256-MB-DDR2-SDRAM-PCI-Express-x16-Graphics-adapter-/73799324
but I can't get it to work with soft15khz.
Anyone using or tested this card? I'm about to call it quits...  :(
All help appreciated
B.
« Reply #8 on: December 17, 2012, 05:01:03 pm »
You're probably running into the no support for low pixelclock (dotclock) issue. Search this forum for some info.
TheBishop84
  • Last login:April 16, 2018, 07:40:34 am
« Reply #9 on: April 16, 2018, 07:39:26 am »
I just installed a Toshiba Tecra S1 laptop in an old cabinet. With it's ATI Radeon 9000 it's perfect for this application. With soft15khz installed, the LCD screen stills works fine. It even has a PS2 port for the older X-arcade controls.
retrometro
  • Last login:May 24, 2024, 09:11:44 pm
    • Arcade, mame, retro... and the gp2x.
« Reply #10 on: October 08, 2020, 08:14:48 pm »
It's 2020 but I want to add that I'm running soft15khz with ATI Radeon X700 successfully on Windows XP 64-bit
-------- gp2x and retro... play it forever! ------------------------
http://www.youtube.com/view_play_list?p=0EE573E86D5A86E0
