Author Topic: Frustrating i-pac problem  (Read 3284 times)
.trunzx
  • Last login:February 08, 2013, 10:28:21 pm
« on: April 23, 2012, 11:49:54 pm »
I'm having a strange issue with my I-pac4 that I cannot figure out. Basically I have a 4 player setup, 1 joystick for each, 6 buttons for players 1 and 2, and 3 buttons for players 3 and 4. Each player also has a start button. Anyway my issue is that whenever I try to map the controls I will have 2 buttons bound to 1 key. For example my player 1 UP will also trigger player 3 button 2. Usually its an arbitrary key like J that is bound to 2 of my switches. I've tried programming the ipac but that doesn't seem to work. I have quadruple checked my wiring and it's all in good order. I'm all out of ideas at this point. Anyone have any suggestions?
MTPPC
Re: Frustrating i-pac problem
« Reply #1 on: April 24, 2012, 12:07:10 am »
Make sure your ground is really good. Figure out why your i-pac4 won't program. There have been a few duds from what I have read, but most of the time complaints are operator error. If it was a Chinese junk board, I'd blame the board first, but j-pac and i-pac seem to have better quality control.
http://pinballmd.com/
.trunzx
« Reply #2 on: April 24, 2012, 12:24:45 am »
I'll check the grounds again, I have players 1 and 2 on 1 ground, 3 and 4 on another ground.
I should mention that I had it working once by dumb luck. I unplugged it, put it back and programmed and somehow it was fine. Too bad I had to reformat :(. Now, no matter what I do it will always assign 2 switches to 1 keyboard key.
alfonzotan
  • Last login:August 10, 2025, 04:06:03 pm
    • The Cab With No Name
« Reply #3 on: April 24, 2012, 07:12:59 am »
Has that card always worked properly?  A while back several IPAC4's were shipped out accidentally with IPAC2 firmware installed... I got one of them.  Nothing worked until it was flashed with the correct firmware.
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« Reply #4 on: April 24, 2012, 08:02:40 am »
For any problems with our products its best to drop me an email at andy@ultimarc.com, we can usually sort things very quickly.
Andy
