Author Topic: what kind of sanding paper?  (Read 2420 times)
trashcan
  • Last login:January 09, 2013, 06:13:17 pm
« on: April 22, 2012, 10:59:23 pm »
Im wanting to smooth out and take the paint off an existing Devastators cabinet. I got 120 G but its barely doing anything. Is 60g better for this?
Re: what kind of sanding paper?
« Reply #1 on: April 23, 2012, 12:04:16 am »
You can try paint stripper or a heat gun and a wide putty knife. I have used, and prefer those methods to sandpaper for removing paint.
TopJimmyCooks
« Reply #2 on: April 23, 2012, 09:53:36 am »
Stripper is better, get most of the paint off then smooth it out with your 120.  Experiment, go to a more coarse grit if you need to then sand back up to 120 before painting/vinyl.  Sandpaper is relatively cheap but you get what you pay for.  Sandpaper varies in quality.  Garnet sandpaper (red color) is not as good as aluminum oxide open coat paper (brown, shiny).
trashcan
« Reply #3 on: April 23, 2012, 03:23:42 pm »
Ok.  Well what is the best kind of paint stripper for an arcade machine?  just any type/brand.  Same with Primer and paint,  What brands?
TopJimmyCooks
« Reply #4 on: April 23, 2012, 03:30:19 pm »
Sorry, havent' stripped anythign in awhile.  I know a lot of people have used citrus based.  just see what they have in the paint section and be careful- ventilation, etc.  for paint, there are a lot of variables.  Brushing/rolling or spraying?
« Reply #5 on: April 23, 2012, 03:52:33 pm »
I used 3m safest stripper. It was a bit more spendy, but no ventilation worries. It is a milder stripper, and I was stripping paint to preserve the vinyl artwork beneath, but I felt it was good enough to use on a cabinet even without artwork below. I just brushed it on, waited 5 minutes, and scraped it off with a wide putty knife.
