Author Topic: 3 new projects  (Read 2047 times)
Berdman000
  • Last login:June 18, 2012, 10:53:21 pm
3 new projects
« on: April 18, 2012, 02:48:52 pm »
Centipede, Galaga and Exciting Hour.
So far I stripped the bad NeoGeo conversion off and out of the Centipede, Exciting Hour has a monitor problem, and Galaga seems to have major issues aside from a crappy shell of a cabinet.
It's only time man, just trying to enjoy the ride.
Berdman000
Re: 3 new projects
« Reply #1 on: April 18, 2012, 03:17:23 pm »
Centipede/NeoGeo
Berdman000
Re: 3 new projects
« Reply #2 on: April 18, 2012, 03:19:14 pm »
The Galaga used to be a Mayday, the only info I found was a label behind the coin door.
Berdman000
Re: 3 new projects
« Reply #3 on: April 18, 2012, 03:20:45 pm »
Excting Hour the bezel was reversed, and there is still a sliver of Time Pilot art work peeking around the sides of the coin door.
Berdman000
Re: 3 new projects
« Reply #4 on: April 18, 2012, 03:25:47 pm »
I plan on doing a full restore on the Centipede, but not 100% on the other two, the Galaga is in really bad shape, if I can get the board working correctly I'd like to get and actual Galaga cab and do a full restore, thinking about turning one of the others into a mame cab. I'm still new to this stuff, so any and all suggestions and help will be appreciated.
  • Last login:February 20, 2026, 04:34:18 pm
Re: 3 new projects
« Reply #5 on: April 18, 2012, 05:08:12 pm »
Since the galaga cabinet isn't an original one, you should probably turn that one into a Mame cabinet. Your Exiting hour cabinet looks like a converted frogger or time pilot, which would be good to restore back to one of them.
Good luck with the work!
Berdman000
Re: 3 new projects
« Reply #6 on: April 18, 2012, 10:13:19 pm »
Yeah thats the direction Im heading with the Galaga cab right now. I wish the other was Frogger, haven't played Time Pilot yet, try and find online.
« Last Edit: April 19, 2012, 08:34:40 pm by Berdman000 »
