Author Topic: Monitor NOOB question: Powering a Monitor?  (Read 2083 times)
Hadeys
  • Last login:January 07, 2024, 08:36:03 pm
« on: April 15, 2012, 06:00:59 pm »
Hey guys, I am new to the world of arcade monitors, and I was wonder how you can power one of these without the games power supply?  I have a Daytona USA cab with a Nanao monitor that I was hoping to put in my mame cabinet which is currently using a CRT computer monitor.  I discharged the monitor and disconnected from the PCB, and I've removed the monitor from the cabinet, but I don't understand how to plug it in.  Am I missing something, or is this somewhat complicated?
I should also state that I have heard of isolation transformer, but I'm not sure what it is or how it works, or where to aquire one.  Is this what I need?
« Last Edit: April 15, 2012, 06:05:09 pm by Hadeys »
grantspain
Re: Monitor NOOB question: Powering a Monitor?
« Reply #1 on: April 16, 2012, 06:00:20 pm »
you will need an mains isolation transformer like you stated
if you have a the donor cab then you just transfer over the monitor wiring and transformer
Hadeys
« Reply #2 on: April 21, 2012, 02:34:17 am »
Its a Nanao ms8-26su monitor. I took a look at it today and I was unable to find any way to power it still.  Can anybody give me some insight on this?  Where is the isolation transformer located, and what does it look like?
quintinbiker
  • Last login:September 27, 2012, 12:47:18 am
  • Go big or go home
« Reply #3 on: April 23, 2012, 09:26:31 am »
It normally looks something like this
You normally find it very close to the power cord that goes into the cabinet, from there you'll maybe find that somewhere the ac 110 / 220 volt is split in 2, one voltage will go to the transformer, and the other one to the arcade psu.
Hope this might help.
« Last Edit: April 23, 2012, 09:31:12 am by quintinbiker »
Life is your game
How you win determines your score
How you loose determines your credits
But to play the game you have to have real credits.
That's why I'm
GAME OVER
LIVE TO RIDE
RIDE TO LIVE
Biker born, Biker Bread, When I Die I'm Biker Dead
GEC Tech
  • Last login:May 11, 2012, 09:03:56 pm
« Reply #4 on: May 11, 2012, 07:44:28 pm »
The Nanao monitor in a Daytona does not require an isolation transformer as it has a switched mode pwr supply, the AC input is a small 1/2 inch wide connector 2 pronged at edge of the chassis, it is a rarely used plug in the industry and I have no idea LOL where to get a new one, but as stated it should be in the cabinet
