Author Topic: Guide to building an Xbox powered arcade cabinet from scratch  (Read 29632 times)
degenatrons
Hi,
I started a new arcade cabinet project and have been documenting the build on YouTube and CoinOps4 project forums.  This will be a bartop arcade cabinet that is powered by an original xbox and running coinops4 as the frontend.
It was suggested that i also post updates of the build on this site.  I hope this is the right place to put this but just let me know if it would be better suited to another section.
So this is an arcade build with Xbox. To save room in the small cab i also disassemble to Xbox and remove key parts.  This is kind of the focus for the first couple of videos but we move on to general arcade constuction from part 3.
I have also designed my own marquee and control panel for this cab with "CoinOps4 vs Street Fighter" theme.
Anyway,  please check out the videos and I welcome your feedback.
Part1:
Part2:
Part3:
Part4:
...and more to come
Degenatrons
« Last Edit: April 22, 2012, 07:22:04 pm by degenatrons »
sharpfork
    • KADE
Re: Guide to building an Xbox powered arcade cabinet from scratch
« Reply #1 on: April 10, 2012, 10:19:45 pm »
I know your stuff from the coinOps forum, I really like it.  I've never considered building such a mini cab so I've never dealt with space issues.  Does heat get to be an issue with the case off and space so tight?  I know that earlier xboxes has a fan on the GPU which I guess would help.
Do you have an outline for what else you plan to cover in the videos?  I started figuring out CRT TVs for full size cabs which isn't applicable to what you are doing.  The research I have done on joystick encoders might be something I can help with.
Maybe we can coordinate on CoinOps settings for a cab as well.  I'd likely want to do that on the other site since it is so specific to that software.
racecar
  • Last login:June 29, 2012, 01:36:27 am
« Reply #2 on: April 10, 2012, 11:11:43 pm »
Glad you took my advice an posted here. Really is such a nice cab, The bartops seem to be popular now.
Will be watching this one as I plan to try an build one based off you videos  ;D
@Sharpfork will be asking you encoder questions once I have build mine
degenatrons
« Reply #3 on: April 11, 2012, 01:59:23 am »
Hey sharpfork,  thanks for your reply.
I think the airflow is better inside the cab than in the xbox.  There is actually more space for air.  I can also mount bigger fans easily to the rear.  Typically,  I like to invert the fan to pull air in,  this regulates temperature nicely inside the cab.
I am a little bit adhoc.  I suppose I should really have a plan for the build so you know what sections I will be covering.
I appreciate any help you can provide on joystick encoders. For this build,  I was planning to hack an s-controller for the interface to xbox.  I also took a look at I-Pac with Xbox adapter but this seems a lot more expensive for little benefit.  One interface I am keen to progress is my own encoder interface for Xbox/Coinops.  I am a programmer and have done some work on USB devices previously.  I would like to develop a USB type interface using Arduino (or similar microcontroller) to directly take inputs from arcade controls and convert to Xbox signal (like ipac).  I don't expect this to be very difficult,  my problem is that there is absolutely no documentation about xbox control signals.  The microcontrollers are really really cheap so if i can get this working it will be very accessible for cab builders and very simple to connect.
For the coinops stuff we can pick that up on the other site.  Grateful for any help you and the community can provide.  I have not been using coinops for long.
Cheers.
northerngames
  • Trade Count: (+18)
« Reply #4 on: April 11, 2012, 11:40:24 am »
if it were me I would just hack the xbox controller pcb's.
degenatrons
« Reply #5 on: April 11, 2012, 11:47:09 am »
yes, it is good option but i do ruin a few s-controllers with my soldering and have some dents in my walls :)
I am going to try using a little conductive glue on the pads to hold wire and then lots of hot glue to secure in place so this will be solder-free solution.
degenatrons
« Reply #6 on: April 11, 2012, 11:54:07 am »
Hey,  thanks for pointing me at this site.  Bartops are only option if you are limited for space so they are quite appealing to some.
At some point I will look to build a cocktail or upright cab.
Glad to hear that you are watching the videos and give me a shout if you need any help with your build.  Look forward to hearing how you get on.
  • Last login:Today at 08:50:58 am
« Reply #7 on: April 11, 2012, 11:58:39 am »
I offer hacked Xbox controllers if your solution doesn't work out.   :cheers:
« Reply #8 on: April 11, 2012, 12:23:09 pm »
By the way, does anyone know where I can download CoinOps?
 >:D
 :whap
northerngames
« Reply #9 on: April 11, 2012, 02:57:30 pm »
if you cannot do them yourself then go with HaRuMaN I dont think you wil be very happy with the glue results at all.
if you dont have the contact right and glue it all down and it dont work then what?
degenatrons
« Reply #10 on: April 11, 2012, 04:53:09 pm »
Thanks for the link.  I need to order some of them and this is a cheap price.  I just disassembled an MS trackball mouse and it has a pretty large trackball inside.
racecar
« Reply #11 on: April 11, 2012, 08:47:46 pm »
@degenatrons Once you get some pics up, I think you might get some more love if this is moved to the project section  :)
@HaRuMaN how much do these cost? an what do they actually do, sorry im a noob getting into building a cab from scratch  ???
@pinballjim I bought a cab with a stripped out 2 player X-Arcade in it. Works great with the xbox in coinops! no lag an love the feature to change from D-Pad to stick buy pressing two buttons.
« Reply #12 on: April 12, 2012, 10:43:06 am »
Controller hack for original Xbox is $35, plus the cost of the controller (or you send me one).  It allows you to hook up arcade-style joysticks & buttons to your Xbox.
You get: the D-Pad, both triggers, X,B,A,Y, start, back, black, white, and I can also do the "click" buttons (pushing in the analog sticks).
ark_ader
  • I glow in the dark.
« Reply #13 on: April 12, 2012, 01:36:28 pm »
Or grab a used X-arcade like I did and steal the guts from that.
 >:D
Yes you know where to get it PBJ.  ::)
Just get the package without the roms from the BP's site and use .84.  Odds are you have all the sets already.
If .84 doesn't work for you try .57-70.
What is the going price for a xbox1 controller hack, as I am a poor starving student?   ;)
« Reply #14 on: April 12, 2012, 02:06:55 pm »
See two posts above yours.   :D
ark_ader
« Reply #15 on: April 12, 2012, 04:38:02 pm »
It was a joke.  Maybe you and Howard can go to the autism doctor together?
So was mine,  Coinops 4 doesn't work well with .84 and I figured you didn't have the sets anyway.
Never stick me in the Howard Casto camp.  I'm not a Nintendoh fanboi.  That will not do. :P
racecar
« Reply #16 on: April 12, 2012, 11:04:09 pm »
@HaRuMaN - Sounds good I might need 3 later down the track  ;D
@pinballjim - how do you play Gauntlet Dark Legacy with your tankstick? I find I need to hit the two buttons to change from D-pad to stick it drives me  :censored: crazy.
An I waste magic when doing it  ???
« Reply #17 on: April 12, 2012, 11:21:43 pm »
Currently running a sale until end of April, $5 off each hack.   :cheers:
mo1e
  • Last login:May 28, 2013, 10:07:02 am
  • Do the happy dance
« Reply #18 on: April 13, 2012, 03:13:27 pm »
Niceeee i have now made my mind up on what i am going to do with my dreamcast.....
knave
« Reply #19 on: April 19, 2012, 12:33:51 pm »
It's been four years since I softmodded my old xbox. I've since collected a few more xbox's with the intention of modding them.
Is there an updated instruction set for softmodding? I use the hotswap method since I don't have any of the games.
I probably would want coinops to be the dash...is that possible?
I'd like to try but I'm sure the process has been tweaked a bit since I've last done it. (plus it was a while ago)
Any reccomendations?
racecar
« Reply #20 on: April 19, 2012, 11:33:14 pm »
I think at this point in time There is a dash called Dragon which BP who released Coinops Is working on.
I use XBMC, But looking for a way to boot straight into coinops would be great
knave
« Reply #21 on: April 20, 2012, 02:23:28 pm »
I love XBMC...there was a time when I used the old softmoded xbox daily. I actually used the unleash dash but I always wished I had just used XBMC (I was too lazy to change it)
Now that we are in the age of streaming...there are only a few shows I watch that are stored locally. I find that the Xbox 360 and PS3 work well enough for that.
So now all my old Xboxes are sitting in a box and a dedicated Retro gaming solution would be welcome.
(I lied, I still play burnout 3 on the old xbox on occasion.) :)
« Reply #22 on: April 20, 2012, 02:33:29 pm »
« Reply #23 on: April 20, 2012, 02:45:57 pm »
LOL Haruman's too poor for a flatscreen and PS3!!
 :lol
Heh.  This is upstairs in the gameroom... the PS3, Wii, & 360 are downstairs hooked to the flatscreen.
This pic reminds me, though... you had some sort of solution for multiple consoles, one TV.  I forget where that thread went...  If I remember right, you couldn't hook the Xbox up that way, something about audio grounds.
What was that solution, again?
« Reply #24 on: April 20, 2012, 03:08:48 pm »
Damn, Haruman, that SNES could use a little Retrobrite...
« Reply #25 on: April 20, 2012, 04:06:58 pm »
I have another SNES with a bad video RAM, but the case is perfect.  My SNES in the picture, besides being yellow, is cracked.  I'm just going to swap the guts.
ark_ader
« Reply #26 on: April 20, 2012, 04:42:50 pm »
If you understand Spanish, this guy has a Xbox1 build.
Looks a bit of a mish-mash but I guess he is happy with it.  ;D
DaveMMR
« Reply #27 on: April 21, 2012, 08:49:16 am »
You can get component cable splitters really cheap and you just ignore the fact that the plugs are the wrong color and use them as composite splitters.  I seem to recall some mouth breather on here argued with me that it doesn't work.  I guess copper wire works differently in his world.
That would be me. And I explained to you that I wasn't getting how it worked because I was somehow looking at it backwards or sideways (i.e. I was thinking two plugs - like the NES - instead of the three, like SNES). Everyone's entitled to a moment of empty-headedness - but the fact that you still rather be insulting than enlightening is why some people question you instead of take you seriously.  You can't spend half your time being a troll and then cry about how someone dared to question your advice a year ago.  ::)
That being said, I was going to try PBJ's method but I had a couple of consoles with S-Video hook ups I spent money on years ago.  So I stuck with the switch boxes (got two hooked up) with the main one going to the S-Video input of the TV. The S-Video hook-ups go through that switch box while the regular composite hook-ups go through the second box fed into the first with an S-Video to RCA composite adapter.  The advantage is cleaner picture and less bulk in the back of the TV; downside would mean you have to label the buttons (unless you don't mind blindly poking) - and the extra wiring/adapters.
And back on topic:  Thanks for those videos degenatrons. I never thought about using an Xbox for a cab when I first putzed around with MAME on that console (about 7 or 8 years ago), but now I'm starting to consider it more. Looking forward to more.  :cheers:
« Last Edit: April 21, 2012, 10:40:42 am by DaveMMR »
degenatrons
« Reply #28 on: April 22, 2012, 05:43:34 pm »
Thanks for the feedback DaveMMR.  Part 4 is out at
I'm sure many would be surprised at what that console is capable of 10 years on.  The arcade frontend (coinops) is still being actively developed and has a great community and a new release.
ceddie720@yahoo.com
  • Last login:November 21, 2018, 03:47:53 pm
« Reply #29 on: November 17, 2018, 09:47:26 pm »
Need hacked original xbox controllers. Can anyone help. I have 3 original xbox modded withemulators, want to make into cabinets
  • Last login:Today at 02:35:06 am
« Reply #30 on: November 17, 2018, 10:17:31 pm »
HaRuMaN is still hacking original XBox controllers . . .
Still offering my hacking services to people: (prices don't include cost of controller)
You can send me a controller to hack, or I can buy one for you.  If I buy the controller, I'll add the cost.
I can do other systems as well, ask or PM for details.
Official Xbox Controller (S): $35 shipped
What you get: All buttons and D-Pad, plus both analog triggers (now digital)
*Shipping prices to the US.  Add $5 for Canada and the UK.  Other countries PM for details.  PayPal preferred, funded however you want.
. . .or you can save money and "roll-your-own" with one of Bootsector's XBOXPadMiro firmwares on an Arduino Micro.
« Reply #31 on: November 17, 2018, 10:23:59 pm »
Are you seriously threadjacking me?
Sent from my Moto E (4) Plus using Tapatalk
« Reply #32 on: November 17, 2018, 10:34:48 pm »
BUY A KADE YOU ---smurfing--- PLEB!
« Reply #33 on: November 18, 2018, 12:51:46 am »
Where’s my handy “Buy A Kade” gif.....?
« Reply #34 on: November 18, 2018, 01:11:36 am »
Found it
« Reply #35 on: November 18, 2018, 08:26:12 am »
that looks like it was typed angrily.
jdbailey1206
« Reply #36 on: November 18, 2018, 08:22:10 pm »
Is the Kade store front even open anymore?  I wanted a Kade miniconsole+ but I dont think that will happen anytime soon.
« Reply #37 on: November 18, 2018, 11:47:18 pm »
Yeah . . . don't hold your breath waiting for it to happen.   :(
« Reply #38 on: November 19, 2018, 08:26:05 am »
So you finally going to shut up about it? Guess we'll have to hear about Arduino Micros ad nauseum instead.
ark_ader
« Reply #39 on: November 20, 2018, 06:32:07 am »
No the KADE guys are hard at work making new software revisions like 49 way joystick support, right Scott?
