Author Topic: t-molding slot cutter  (Read 1878 times)
Brian74
  • Last login:April 21, 2025, 11:11:53 am
  • Yep... I built that!!
« on: April 09, 2012, 11:45:45 am »
Where is the best place to buy one?
Re: t-molding slot cutter
« Reply #1 on: April 09, 2012, 12:52:52 pm »
Harbor Freight if you got one near you. Otherwise, amazon or some online store is fine.
  • Last login:Yesterday at 02:17:59 pm
    • GroovyGameGear.com
« Reply #2 on: April 09, 2012, 01:02:17 pm »
If you are only going to use it once or twice, the cheap Harbor Freight ones are fine.  They tend to be flimsy and dull quickly, and once they loose their edge, it can even become a safety issue.  If you want to keep one in your tool box to use whenever you might need it down the road, I recommend getting a quality bit.  T-molding slots can be tricky enough without fighting additional challenges presented by low quality cutters.
Unstupid
« Reply #3 on: April 09, 2012, 02:30:36 pm »
Woodcraft if you have one near you!  CMT Orange bits are awesome!  This is the one I use but it has a 1/2 shank.  They make a 1/4" shank version as well if that's all your router can do.
kahlid74
  • Gaming for a better future!
    • GamersAnon
« Reply #4 on: April 09, 2012, 02:35:15 pm »
I use the ones from T-Molding of Whiteside brand and they work fantastic.  I would recommend them every day of the week.
GregD
  • Last login:December 19, 2024, 04:27:31 pm
    • Arcade Nebula
« Reply #5 on: April 09, 2012, 02:50:19 pm »
Here is an ebay link to the one I purchased.  It is a Porter Cable and good quality.  $10 shipped cannot be beat.  Make sure your router can handle a 1/2 shank.  I wouldn't spin a slot cutter on a 1'4" shank.
http://www.ebay.com/itm/Porter-Cable-1-16-Slot-Cutter-w-1-2-Shank-Arbor-Router-/140442782832
Brian74
« Reply #6 on: April 09, 2012, 07:29:05 pm »
Far as I know mine is a 1/4.
